Where is your dealership?Most recent pic;
I see you are a dealer for B.M.C. but see none in the picture. I use their phono stage and have a pair of M2s.
Why do you think that is? Seems a really odd recommendation.
At the show, Ishiwata is using one of his very typical set-ups, with an extreme toe-in of the speakers designed to take out of the equation the less-than-ideal acoustics of the room in which they're being demonstrated.
Read more at http://www.whathifi.com/news/high-e...ming-arena-eu2999-na-11s1#EPMfKA1Za4U9HjGG.99
Yes, I think he has already done that. I think Carlos is doing factory direct in the USA.
I will no doubt be up there sometime this month to visit High Fidelity Cables to see Rick Schultz. Could you tell me the name of your company?
Advanced Home Theater. The G1's are set up at my house and you are welcome to come by for a listen![]()
right way up ... are you using the dual subs to augment bass or are you using them to smooth the room using distributed bass... ?
Thanks for clarifying. Also: nice room! I can imagine it sounds great with your Vivids!
