Have any Melco S-100 users here tried fiber optic IN to one SFP port and fiber OUT from the other SFP port? I was told by Melco this should work, but I haven't been able to make both SFP connections work at the same time.
Glad they figured this out - my Linn KDSM clearly sounds better being connected this way instead of S100->N10->Linn KDSMMelco has realized their manual failure and have changed the manual.
My S-100 is from a relatively new shipment, the manual shows the following picture:
OK the switch has arrived!!!Maybe if my sfp+ fiber optic system will work! (the network card on my PC should drop speed requests!)
update, two GS2016s arrived from japan (unfortunately still in Japanese language), with the melco S100 I noticed packet loss at 100Mbps full, but configuring the Buffalo ports with the second option (which is in Japanese I can't translate it) now it DOES NOT lose the packages! the sound also seems to have almost a greater bodybut using the inputs at 100 (1-4) I lose packets, reproduction impossible! I therefore had to connect the dCS Bridge to the outputs at 1000 (ports 5-8)
WowA My Buffalo piace anche tornare al giapponese nell'interfaccia utente di gestione. È possibile tornare all'inglese selezionando la prima lingua nell'elenco in alto a destra dello schermo. Assomiglia a questo:
Congrat on the new m12 gold. You will be happy with it pairing with plixir elite LPS.Been reading messages on networking here and in Audiophilestyle in the last couple of months, to learn as much as I could before my next plunge into the rabbit hole.
I had first tasted how a quiet network improved the SQ tremendously when I purchased a Melco N1 music library with a filtered lan port to connect to the DAC. When S100 came to my shore last year I grabbed it and never looked back since. The sense of calmness in the music had me staying loyal to it until a couple of months ago when my Melco dealer called me on the availability of ADOT fiber kit.
Before I took the plunge I started to do my research and bought cheap kits from China, such as $5 media converter, $5 multimode transceiver, $2 fiber cable and $60 LPS to try out.
I learned along the way that for a fiber kit to sound good, power supply and transceivers are all keys. So I switched to single mode, starting with Finisar 1321 and 1324 and now 1471. Instead of cheap media converter, I bought Edgerouter as someone had strongly recommended. I also upgraded the fiber to Commscope (I was surprised that fiber cable made a huge difference - bigger soundstage in this case) and got myself Plixir Elite LPS.
Every change yielded a different sound. Whether it can be considered improvement is debatable because each configuration suits different kind of music. But the journey was very enjoyable. It’s a good distraction from the current pandemic situation.
Instead of getting rid of the multimode fiber kits from China, I used them to isolate my main router from the noisy household internet traffic and TV set top box, after turning off the wifi of my main Asus router as recommended by a poster in this thread.
So what’s next? While still having the strong momentum in improving the audio network, I finally decided to fork out many times more of what I had spent previously and took the plunge to order the M12 Gold. This will be the last leg of my journey and as we started to go back to work in office, the upgrade has to stop and listening to music will begin
Thanks for reading and below is my network diagram (M12 Gold is yet to be hooked up as I’m still waiting for the LPS). Any comments will be much appreciated.
View attachment 81163 Yellow - fiber connection. Black - RJ45.
Looking forward for your impression.Plixir is hot. Gotta wait 2 weeks for my bespoke power supply for the M12. James (from Plixir) recommended 6A to extract the best sound out of M12.
I'm using this setup with my Linn KDSM Organik, I was previously using a Shunyata Sigma ethernet cable. The fiber sounds better.Have any Melco S-100 users here tried fiber optic IN to one SFP port and fiber OUT from the other SFP port? I was told by Melco this should work, but I haven't been able to make both SFP connections work at the same time.
