Is XDMS release anywhere on the Horizon?
Wow - 999 pages! You’ve all been busy.
Both.
Doesn’t look like it- there are many day 1 features which haven’t been worked on yet.Is XDMS release anywhere on the Horizon?
Wow - 999 pages! You’ve all been busy.![]()
I had the same problem. It turns out they shipped, in my case the switch, with a screw/bolt that is a bit longer. I didnt want to overtighten it, so I was going to add some washers. Instead, I happened to find a replacement screw. You can contact support as they offered to send me a shorter replacement.For those who have the dc distributor: does your grounding screw screw in all the way? Mine stops halfway, and so I have no tension on my grounding cable which keeps dropping off.
Very brave! I know that I wouldn't have the cojones!The most difficult part of the A-B-A test was teaching my wife how to switch between XDMS and ROON etc. That was a nail biter![]()
The XDMS build out has been delayed by several months by the need to build functionality to send information on music playing activity to the streaming service. This is done and certified. The focus has returned to getting the Beta release built out.Doesn’t look like it- there are many day 1 features which haven’t been worked on yet.
Steve, this is exactly what I did. I found another bolt that was a bit shorter and it worked perfectly, saving support the hassle of shipping me a shorter bolt. Ted did offer to ship me a shorter bolt, but I found one at my local hardware store. FredWhy not just go to the local hardware store purchase two shorter stainless steel allen head bolts?
Total cost less than $2 USD. Even in the very small town I live near there are at least three stores that have what are called "small parts" displays -- bins full of assorted stainless, brass, steel and nylon small fasteners of all standard sizes. Nuts, bolts, washers and specialty fasteners. Just take the original too-long bolts with so that you get the correct diameter and thread pitch.
For those who live in areas where this kind of fastener is not readily available Taiko could perhaps mail a pair of the correct bolts to the affected customer(s).
Steve Z
Unscrew the one you have and take it to the store to match it.It would be nice to have the specs for the new screw. Metric? Length? Etc.
The screw that was sent is M6 10mm. There are M6 6mm and 8mm hex screws on Amazon, and M6 8mm Philips on WalmartUnscrew the one you have and take it to the store to match it.
Thank you. There were no l's or i's in the pw that i saw. There's what appears to be a 1. The same character is in the wifi password and that works as a 1. But I'll try l and iFor 1) What's most likely the problem is that an "L" in lower case is actually an "i" in upper case. Try different combis of that (or zoom in and look very very closely) and it should work.
Drats. That's not the case with other routers ive used.Even if you are hardwired into the router you still need the admin credentials to log into the router.
I tried replacing the 1 with both I and l with no luck. Best I can tell there's an issue with access to the router admin console.Thank you. There were no l's or i's in the pw that i saw. There's what appears to be a 1. The same character is in the wifi password and that works as a 1. But I'll try l and i
I've been using the password that came under the router. Where's the other password?Does the password on the bottom match the password on the small sticker that came with the router? That has the credentials too.
Not to interrupt the current password debugging issue... but thought it might be cool to reflect on the inaugural post now that 20,000 have followed.... thank you @CKKeung! a gift to WBFEmile of Taiko Audio told me that he has been very busy to fulfill the orders of SGM Extreme for his Korean customers and he doesn't have time nor energy to start a thread on WBF.
Let me do it for him.
Here are some of the spec of the Taiko Audio SGM Extreme :
- -Dimensions 483*450*180mm including feet,
- -Weight: 42Kg / 93lbs.
- -Dual Xeon Scalable 10/20 core CPUs.
- -48Gb (12*4Gb) custom memory modules.
- -The 2 cpu’s and 12 memory modules are not shared but split into 2 domains, 1 dedicated to the operating system, 1 dedicated to music related services and playback software.
- -All storage is directly connected to the Xeon CPU integrated disk controllers, no sata ssd’s / controllers used. Maximum number of drives supported: 24.
- -400 watt high current powersupply, lundahl chokes, ~700.000uF mundorf electrolytics, duelund pure silver foil bypass capacitors.
- -Custom Windows 10 Enterprise LTSC 2019 OS.
- -Playback software: Roon + Jplay, HQplayer optional.
- -Completely passive cooled, no fans.View attachment 65922
