Report from Asia. Update was quick and easy. All via Taiko router and switch. Sound is more holographic, bass more solid, more 3D. I am solely a Roon user. Cannot be happier!
So when you say shut down any other Roon cores/Endpoints. In my case I only have Roon on my laptop and ipad. Are you suggesting in my case to only use one Roon application? Delete/remove the application on the laptop. Or does this not matter? I never have both open at the same time and never really use the laptop as remote, only the ipad.
Its pretty cool that here on WBF with many listeners together we can contribute what we are hearing and then you expand the diagnosis...
So is/was the crux of the issue the following: Roon was set to launch as start up from the the Extreme Taskbar. When you also have XDMS installed and use it, Roon must not be set to start automatically. When on manual, it will enable using the toggle in the XDMS app. Christiaan on Monday started from the Extreme Server. Is this the extent of the upgrade or is something further needed?Shut down the laptop for maximum SQ.
Disregard, Khyle did the complete Upgrade...So is/was the crux of the issue the following: Roon was set to launch as start up from the the Extreme Taskbar. When you also have XDMS installed and use it, Roon must not be set to start automatically. When on manual, it will enable using the toggle in the XDMS app. Christiaan on Monday started from the Extreme Server. Is this the extent of the upgrade or is something further needed?
1353...What Roon build are you guys running after the Taiko update? When I load Roon after the Taiko update it is still asking me to update Roon. That doesn’t seem right.
Try this, toggle to XDMS, open it. Then toggle back to Roon...That’s what I would have assumed mine would running but I am still on 1311.
Whew! I broke into a cold sweat just reading this!Ta da, thank you, Dave!
There are two independent matters:So when you say shut down any other Roon cores/Endpoints. In my case I only have Roon on my laptop and ipad. Are you suggesting in my case to only use one Roon application? Delete/remove the application on the laptop. Or does this not matter? I never have both open at the same time and never really use the laptop as remote, only the ipad.
Have you tried stopping the TaikoRoon process, starting Roon natively, and then doing the Roon update?That’s what I would have assumed mine would running but I am still on 1311.
Disable block automatic updates.
I'll be in touch with you via mail...Khyle has been updating my machine. Shouldn’t he be doing all this? I don’t want to mess him up.
Emile means simply allowing all updates in Roon (in case you had disabled this).John, it isn’t updated. Khyle confirmed.
Khyle said he ran into issues updating my machine. I have been waiting for his instructions. Should I do this regardless?
