second that, did anyone try the copper version sold under the Viborg brand? (haven't gotten around to that, they are fairly new IMO)
https://www.audiophonics.fr/en/schu...huko-plug-pure-copper-250vac-16a-p-15925.html
I can't speak for Schuko receptacles, but I've been using Viborg AC plugs and IEC connectors for years on DIY cable projects. I'm pleased to finally see someone like Emile say flat out that rhodium receptacles are poor performers. Caelin Gabriel told me the same thing many years ago. (Audiophile fascination with rhodium should have died long ago!) I've used Furutech plugs made of copper and silver (FI-48) as well as gold plated copper and think the Viborg products are every bit their equal at a far lower cost. Very high quality fit and finish.
As far as receptacles, I've outfitted my music room as a lab for AC receptacles of numerous metals/brands that offer a great advantage in that I can simply swap plugs into numerous receptacles for instantaneous comparisons (see post #4)
I’m been meaning to write this up for a while and now it seems like the sort of essay whose length is more suited for an assignment on “what I did on my summer vacation”. When I built my home a few years ago, I had enough foresight to know I should provide plenty of flexibility for the power...
www.whatsbestforum.com
The bottom line is that Shunyata CopperCONNs are my receptacle of choice but I am not sure they are commercially available unless you buy a Shunyata conditiioner. However, good old 8200 Hubbell connectors are easy to find and are nearly their equal. (Those contacts are brass, which is an alloy that contains about 70% copper). Also note that anything using pure copper is subject to corrosion which is why any receptacle that is made with copper contacts are generally flashed with nickel (as in Shunyata's case) or gold. Viborg makes receptacles with "Red Copper" contacts but I have no experience with those. I can't even figure out what "Red Copper" is! (It may refer to a red ore variant known as cuprite, but I am not sure.)
One of the things I've learned about metals and cables is that while everyone pays great attention to what metal is being used in their cable of choice, few pay attention to what I think is of equal importance, which is namely, the metal connector that your cable is plugged into. In the case of the Extreme, Emile told me their IEC chassis termination is an Oyaide 004 IEC male connector. An Oyaide 004 connector uses connectors made from beryllium copper that is polished twice. Then, a layer of platinum (.5 micron) is plated directly onto this polished surface, and the polishing process is again applied twice. Next, the 004 receives the final Palladium plating (0.3 micron), and is again polished twice. The combination of these polishing processes, platings, and
thicknesses of platings ultimately leads to the final sound character. Therefore I currently use a custom AC cable with an Oyaide 004 IEC female connector to avoid any adverse dissimilar metal interaction with the 004 IEC receptacle used in the Extreme. This works very well for me.
Although I replied to a query about Viborg plugs/connectors in this thread, it would probably be best for any cable discussion that does not pertain specifically to the Extreme to be continued elsewhere. There are many such threads to choose from.
