David:Neil, thanks for the detailed response. I had tried a 3 fan computer radiator before but I found that the higher readings on the TDS meter indicated there could be some interaction between the cleaning solution and the radiator.
This is the radiator I used: https://tinyurl.com/89npepuc
It is copper so that may be the issue.
If I can just drop a radiator between the pump and filter and the pump will keep things flowing I am open to trying one of your solutions. Even with the 70% power the temps were too high to do multiple cleanings back to back.
These radiators come in different configurations - some just have threaded female fittings so you pick the male bared fittings of your choice. Otherwise, there are always barb hose reducers -Quickun1/2" to 3/8" Barb Reducer Hose ID Reducing Barbed Splicer, Round Union Fitting Intersection/Split Water/Fuel/Air: Amazon.com: Industrial & Scientific.It would also be helpful to find a radiator that has 3/8” fittings so all the tubing is that same.
Good Luck,
Neil
Neil, your assistance and knowledge are invaluable. I am going to order the Koolance and let you now how things go after it is all set up.
I did notice that by the end of 20 minutes (10 @ 37 Hz @ 70% and 10 @ 80 Hz @ 100%) the temperature was 35 degrees C instead of 33 or 34.
This will be an interesting experiment.
Is that using the tank heater set at 30° C?
Tim,I presume heating the solution has value to the extent the surfactant is more effective at a higher temp than room temperature. Here is a question for Neil (apologies if your book has the answer): At what temperature is Tergitol 15-S-9 most effective and does its effectiveness rise as the solution moves toward that temperature?
However, "XIV.2.a Temperature: For water, beyond about 40°C/104°F, the cavitation intensity can decrease.". Lower kHz (60-kHz) cleaning efficiency can increase by about 10% up to about 60°C/140°F. Cleaning efficiency is the combination of cavitation intensity and cleaning ability of the fluid. However, for higher frequency (132- kHz) units, cleaning efficiency peaks at 40°C/104°F and then decreases rapidly.
But records are temperature limited, so, its all a balance to get the best cavitation intensity with the best wetting/detergency with the lowest concentration otherwise you compromise the process with excess foam and then rinse tank burden. BUT, most of what you are trying to clean in your UT tank is particulate, so detergency is not as important - you want to optimize wetting and cavitation intensity.
Tim,Thus far I (and I believe David as well) have kept top temperatures in the 30°C - 35°C range. The idea being to assist the cleaning ability of the fluid while not damaging the vinyl.
I read that beyond 60°C vinyl records will warp. (The maximum heating plate temperature of a Furutech LP Flattener DF-2 is: 57?±3? ) I speculate that temperature lower than that (and some solvents) can soften certain areas on a vinyl record, such as groove ridge peaks - again speculation on my part - which may or may not re-harden to their original shape.
All of this as part of my wondering if increasing maximum temperature in the USC tank can yield a better cleaning process while remaining safe? For example, 40°C at 37kHz and 45°C at 80kHz.
As you say we're primarily trying to remove particulate, so detergency is less important. I enounter little grease or fingerprints on my records - at least that I know about. Then again, as you note, contaminants can mask particulate.
Optimal tank state for optimal cleaning while erring on the side of safety - yes, it is a balancing act. Imo, it is worth having some sense of state-of-art with off-the-shelf components - a model - that we can point at, given what we know. Over time we have refined the tools, the components (tanks, filters, etc.). I wonder if we can refine the process further.
Tim,
Temperature can improve the cleaning efficiency - the mechanism for a record may get complicated by a thermal property called the Coefficient of Linear Expansion and in english units is referred to as in/in/F; and for PVC its about 0.000032-in per in per F; and this can also be expressed as 0.81 microns/in/F. So if the record heats from ambient (25C/77F) to 35C/95F, the record will expand by (0.81 microns/in)(18F) = 14.5 microns/in. If we were to assume the record 12" diameter, the record could expand in diameter by (14.5 microns/in)(12-in) = 174 microns = 0.007-in. You will not see this, but expanding the record 'may' loosen tightly adherent particles. FYI - metals do not expand anywhere near this amount.
However, there is another property of plastics known as the Glass Transition Temperature (Tg), and this is the temperature the polymer structure turns “viscous liquid or rubbery" - it gets soft. The Tg for rigid PVC is ~60C, plasticized PVC is ~50C, and I suspect the record PVCa is ~55C (131F). I have a Vinylflat that I made my own heater (aluminum plate and a 25W heating element) and 131F for an extended length of time (i.e.1hr) can damage a record (distortion & noise) - I do not exceed 124F (51F); but I do a very slow heat-up/cool-down.
The closer you get to the glass transition temperature with high powered ultrasonics you may enter a zone where you can do damage noting that records can have a range of composition so that the glass transition temp could be closer to 50C for some records. My recommendation for max temp would be 35C(95C) @ 37kHz (noting that this frequency has the highest risk of damage) and 40C (104F) @80kHz with the goal to operate 100% power (with pulse) @80kHz. You want a comfortable 'safety' margin between your UT tank temp and the Tg.
Good luck,
Neil
Is this an argument for using, or at least experimenting with, our flatteners as part of the cleaning process...?You will not see this, but expanding the record 'may' loosen tightly adherent particles. FYI - metals do not expand anywhere near this amount.
I do not think so.Is this an argument for using, or at least experimenting with, our flatteners as part of the cleaning process...?
Indeed. I always wash records prior to flattening for this very reason. I have no evidence that this occurs, but simple intuition suggesting it might.If anything, as the record heats up constrained and softens, this may more deeply adhere particles into the grooves. If anything its a good reason to make sure the record is as clean as possible before flattening.
There are also macroscopic bubbles appearing in the tank from time to time. Neil, does it make sense to add say 3% of ethanol to the rinse tank to improve wetting (I was using 3% ethanol for the vacuum rinse with good results)?
he biggest change is that the boiling-temp (vapor pressure) drops by 12degC and you can see what happens with Isopropyl in Figure 32. This drop in vapor pressure is a double edged sword because it speeds up the drying but it also reduce the cavitation intensity.
You will get some cleaner carryover - even if you let it dry. 0.02% Tergitol = 200 ppm = 200 mg/L = 0.2 mg/L.
-For the rinse tank, you can try ethanol and see if that improves the end product sufficient to warrant the burden of now having to monitor the alcohol concentration or refresh the rinse tank frequently enough to mitigate.
Tim,Edit: I always wondered if IPA was the 'secret ingredient' in Lloyd Walker's 'Ultra Pure Final Rinse', part of his Prelude system, pre-ultrasonic. Since we are rack drying, I might try it. The trade-off, as you say, between reduced drying time and cavitation intensity. Do you have a suggestion for a good balance?
In an industrial throughput environment the records would be dried under a tox-hood that would ventilate to outside, or an air filter with activated carbon/charcoal which can absorb alcohols (and other volatile compounds) - Microsoft Word - TIB Activated Carbon Adsorption List.doc (ipsystemsusa.com) would be used.
