So...after an initial read I am thinking about using a hybrid approach for my (mono) Vinyl records (at least 60 years old).
Something like;
1- pre-rinse
2- pre-clean
3- pre-clean rinse
4- acid clean (think I found alconox powdered acid cleaner 'alconox powdered precision cleaner', else distilled vinegar)
5 acid clean rinse
6- final clean in US bath (surfactant TBD)
7- final rinse in US bath (TBD as a second US bath setup probably is required) or rinse
8- last rinse with DIW
9- dry (PVA sponge)
10- second dry
Following up with what
@tima just wrote:
1. If you are going to US bath clean, you do not need the acid clean. As I wrote in the book PACVR, Chapter XII, "The incorporation of the acid chemistry does manually what ultrasonics can do with power.".
2. The powdered Alconox product is a higher-pH alkaline cleaner and does not rinse as easily as the Liquinox. Not knowing where you are, you may be able to buy Liquinox from the UK
Alconox Liquinox 1232-1 Critical Cleaning Liquid Detergent; 1 QT Bottle from Cole-Parmer United Kingdom (coleparmer.co.uk). However, unless your records are very dirty, you should be able to eliminate this step.
3. For a nonionic surfactant and your US tanks, again not knowing where you are, here are two options that you would use at about 0.0150% concentration:
-If in the UK, you can buy
Dehypon - 1 Litre – Conservation Resources (UK) Ltd (conservation-resources.co.uk).
-If outside the UK, you can buy Polysorbate-20. This is generally readily available worldwide and is environmentally very safe. It's not as effective as Tergitol 15-S-9 or Dehypon, but it's good enough.
4. The PVA sponge is used for the manual procedure where the record is held in the label protector, and you are not handling the record. In US bath clean, as
@tima says, you do not want to over handle the record(s), so you are better off letting the records air dry - just keep the general clean, and
@tima I believe uses a HEPA filter. Especially, if you are cleaning many records at a time.
5. Otherwise, you do not mention how many records you need to clean. Depending on the number, there are different hardware combinations such as some people use US bath for cleaning and a vacuum-RCM for rinse/dry. But you have to be honest with yourself as to how much manual labor is OK, will the noise of a vacuum-RCM be a showstopper, how much convenience do you want, and how much do you want to spend. Note that the inexpensive US baths can be very noisy, enough to drive many people from the room.
6. A simple US cleaning process can be a 40kHz Humminguru for pre-clean and a 120kHz Degritter for final clean/rinse, dry. These US units clean only 1-record at a time, but they both use drop-in spinners which makes it very convenient and fast to move the record from one machine to another.
Good Luck,
Neil
