Are you seeing the para normal Bob?
It didn't occur to me right away.
I use tonal depth, sometimes tonal richness.
You read my mind Northstar.I like the word "density". Where did you get it from Ked? ...TAS?
Density is quite commonly used Bob, Marc also v uses tonal density to describe Zus often
I think that is more equal to tonal density, and if density used on its own refers to rest of the sound too, the who stage is dense. Some components give a lighterfeel to give an example of the opposite.
Fuller orchestrations with multiple simultaneous lines are dense - thick with sound. Brahms' symphonies and choral works are dense. Tonal depth is about purity and the fundamental relative to the instrument and relative to its clarity. Richness is depth and harmonics/overtones - the opposite is thin, less developed. These are words/phrases I use in my writing to describe sound and music. It's a bit dicey to apply such to components, or at least I try not to write that way.
"Another notable moment came when Mr. Nishikawa played a Louis Armstrong LP. The pitch definition was so exact that it was something of a revelation for me to listen to Armstrong’s trumpet solo: There was a density to the burnished sound that I had not previously experienced."
Some writers use visual words - a word describing how a thing looks - to describe sound. Granted it is difficult to convey something one has, until now, never experienced. But I wonder if he really does mean 'burnished'? I don't know what that communicates.
I agree with your description, but some components can make the symphony sound more dense as opposed to another that is lighter. Valve rolling too, some valves give a denser sound than others. Also recordings can have a denser feel, for example some original rock pressings have great bass that adds density while later pressings have very light bass
Yeah I was wondering the same thing about burnished when Bob posted it. For me burnish has a tweaked up connotation, but I don't think that is what the writer was intending he meant it positively
Burnished is a puzzling word choice here, I mean who rubs sound to make it glow? Burnished metal is reflective and brilliant and the surface is hard, it just seems a awkward fit in the context of usage. There is a desperate searching quality to this choice. The word was heroically levered into it’s poor fitting place and uncomfortably screams with a very real burnished quality... well look at me, I’m just here looking all adjectival but still somehow I’m lost for meaning, I am unclear, unhelpful and largely inaccessible... the sentence would probably look better without me.Some writers use visual words - a word describing how a thing looks - to describe sound. Granted it is difficult to convey something one has, until now, never experienced. But I wonder if he really does mean 'burnished'? I don't know what that communicates.
Pimped up is just more easily stylish and bold... its colour comes from its self confidence.Unfortunately, it resonates with me because on the techdas thread I used the word "pimped up" to describe its bass, and burnished means similar, though his intention I am sure was different from mine
