Generally anyone with an average pair of ears and half a brain can hear what a feedback loop does to the sound
The problem is the eyes, they can see the price tag
The worst ones are the ones that count RPM. They can have wildly inaccurate speed stability but as long as they speed up or slow down at some point to hit their RPM target, well they're "correct".
Some designers want to make their product idiot proof so they use some sort of feedback loop and a pretty display. More often there's a need for some sort of feedback/control system even if there's a sonic penalty, I've seen quite a number of turntables that won't hold speed for various reasons and the easiest way is to introduce a feedback loop. I've never heard anyone claim that the sound improves by using a feedback controller, at best they say that it's inaudible or barely negative.
In case of belt drives and idlers the concept is very easy to demonstrate Francisco with just On or Off! Generally anyone with an average pair of ears and half a brain can hear what a feedback loop does to the sound but sadly the latter seems to be challenging for some.
david
I can't answer that Francisco, never ran any tests with tape decks and been decades since I had R2R at home. Just remember that the cheap Japanese ones were advertised with Quartz control or something to that effect.David,
Thanks , I never considered that absolute accuracy to .01 % is an important matter. I am just addressing technical aspects of feedback and its correlation with subjective sound. The same reasoning you apply to feedback could be applied to driving synchronous motors with three phase supplies or a de-phasing capacitor using a single phase : considering that one of them is the wrong way of doing things just because we prefer one of them.
Any way can you address my question concerning if "the negative effects of feedback loops and servo controllers are easily demonstrable and audible" in capstan tape machines?
Surely. But fortunately most manufacturers are more clever than that.
People who are worried about feedback and use turntables using an AC motor driven directly by the mains should consider that unless their amplifiers are class A they can have terrible feedback in their systems - transients will affect mains voltage that will instantaneously change motor torque ...
david
In fact top reel machines such as the Studer A80, the A820 or the Ampex ATR 102 have servo-controlled, direct-drive-capstan tape transports. My Studer A80 using a few Tapeproject master tapes is still my analog reference for ears and brain calibration.
My point is that usually we have good and poor implementations of techniques, but we should avoid diabolization of concepts. Twenty years ago many people were against using digital circuits with DACs to build wave synthetizers to drive AC motors in turntables - probably because of experience wih poor designs, that could radiate high amounts of RF noise through power cables and the motor. Today we see manufacturers and modifiers using these same digital techniques to drive three phase motors of high quality turntables with great success.
Which TTs use this technique?
i guess the real question is whether reality is the reference? or the source? do the drives on platters for cutting heads on lathe's have speed controls? my (admittedly minimal) understanding is that they are all direct drive. with servo's.
so if the master recorders, and the lathe's, are both servo controlled, how does a tt not using a servo somehow stay pure? does it fix the problem? or is there not a problem?
and.....maybe......it's all execution.
just say'n.
i got no answers.
Carolus, how do you change phase on that FR-S520S? I don’t see the option in manual but maybe they have confusing way to say it? The device is obviously based on switching tech, so still a bit noisy.
What's the relevance of tape machines here? There's nothing in common between magnetic tape and the vinyl lp, what is it that you're comparing here?
david
David,
My point was that with turntables even the best implementation of a feedback loop still has negative sonic impact.
david
I am thinking the same. Needle gliding uneven groove and smooth tape passing tape head is a different means of reading signal. Talking tape suppose to shut you up and not argue about its sq using feedback David. Because tape for us all audiophiles should be taken for granted even without listening as the ultimate in sound and the mother of all sound reproduction...hehe.
Tang
