so no need for a taiko?
the idea that a dac, any dac, might somehow overcome lesser quality data streams is nonsensical. garbage in/garbage out. the more pure the dac, the more the lack of quality it is fed gets revealed.
will we all agree on what is best or most transparent? no. but that does not change the basic idea.
the best source/server/transport will push the best dac further.
ignoring interface synergy, i agree with you. these days many transports have proprietary interfaces that might be a factor in dac choice, or dac performance potential. so it's not as much a better/best as the right match.yes, but the point is your decision of best transport will not vary with the coupling dac. What you think is the best transport will be true even if you change dacs (with the exception of having to play SACDs)
Interesting. You just heard a really good sounding system played an old Studer cd player. Your ears must have told you this could be one of the best system you have heard. What does that tell you about where that great sound came from? The dac?yes, but the point is your decision of best transport will not vary with the coupling dac. What you think is the best transport will be true even if you change dacs (with the exception of having to play SACDs)
My experience is that the quality and resolution af files, the server/transport ie hardware and software and used protocol of transmission are as important as the DAC itself. For example the playback of DSD files improved in my system with the recent update of W20 which enabled native DSD transmission instead of DoP . The hardware is nearly 7 years old but the new soft may improve a lot.i think that when we are talking about phono cartridges, tone arms, and phono pre's, the best one's of each category are able to take most advantage of the best partnering product. there are also issues of synergy too. so the most capable of one piece of the chain does not reduce the advantage of better partnering gear, it increases it.
the same for dacs and servers, and throw in interfaces and cables too. better partnering gear advances the result. period.
The best native dsd files I have are not edited and mastered after recording ( for example Fone recordings) .My experience has been that the mastering of the digital files is way more important that the resolution even when played back natively.
so mike let me ask you this. Since your an msb guy and all. how many times has msb made new usb input boards on there dacs ? How many on yours from the sel 1 to your 2 revision ? i recall Vince and others continued improvement of the usb input was based on fixing the many issues of data streaming audio period. writing new software for various formats. All of this makes the dac less dependent on a given level of server.i think that when we are talking about phono cartridges, tone arms, and phono pre's, the best one's of each category are able to take most advantage of the best partnering product. there are also issues of synergy too. so the most capable of one piece of the chain does not reduce the advantage of better partnering gear, it increases it.
