steve williams
@Taiko Team
TAS BETA HAS EXPIRED. Please don’t make us use Roon
I have to go through TAS to get to Roon the way I'm set up.@Taiko Team
Strength in numbers
@Taiko Team
So what now we waitI believe any test app is active for 3 months and then it requires a renewal. That’s what Taiko has been doing for a couple years.
So what now we wait
Yes I did that , but had to manually lunch Roon Server since it's not setup to launch at startup which makes senseIf you reboot the Extreme it should default to Roon and you can use it that way without having to run the TAS app.
Same for me. Now unable to get to Roon and all the music files in TAS Beta.I have to go through TAS to get to Roon the way I'm set up.
Check your iOS or Android app now -- the Testflight app has been updated by Taiko and the Taiko Audio app (TAS) just needs to be opened. E-mail was sent about an hour ago from Taiko.Same for me. Now unable to get to Roon and all the music files in TAS Beta.
Roon not being set to launch at startup when running TAS is indeed done on purpose as having it run in parallel affects the sound. It's always best to have only one server program running.Yes I did that , but had to manually lunch Roon Server since it's not setup to launch at startup which makes sense
I'm confused. I'm enjoying music using TAS right now. Is this something that times out by user?
@Nils I agree with your findings, to the extent that an external observer would say I have become a bit obsessed about DC supply quality to every part of my system, including ISP modem and router.Team,
I'd like to share some findings from recent upgrade that I made to my system which I think may be of interest to quite a few amongst you.
So, this was not a bad setup...
But I thought that it was quite some time since I updated the power supplies of my Netgear Orbi MESH-system from stock to a little better IFi low-noise switching supplies so - time to explore.
This is a HUGE improvement, each step made it better, feeding the Hypsos from Everest was the biggest step-up, but the very first step of removing the Wall-wart from the Fiber converter was also major.
Lessons learned:
1) Optimize the whole
2) Include equipment from your service provider (fiber converter in this case) - most have wall-wart -> easy upgrade and no violation of policy (keep the wall wart around in case they need to come and service their equipment)
3) Router is as much part of your system as anything else - it deserves proper clean current via decent power cable
I tried out Keeces p3 LPS before moving to Ferrum (I have used them before) - they offer great sonic quality along with fantastic build quality and great versatility - recommended.
