My reference to everyone agreeing that flat on axis speaker response and listening window response is correct is in terms of ANECHOIC measurements (or software like the Klippel which apparently can mimic anechoic measurements even though taken in a real room) of the type shown in spin tests.
I'm NOT talking about the usual in-room-point-a-mike-forward-toward-speakers-from-listening-position that I and many others do. Such measurements, if they show truly flat response on top indicate the speaker is way too bright/aggressive sounding in that room. And if the bass response is very flat in such a measurement, the speaker will sound thin. Thus the preference for target curves for such measurements to be a bit up in the bass and a bit down in the treble.
If you don't believe that anechoic speaker measurements on or near axis should be flat, then you are accepting a different standard for speakers than all other audio equipment in the chain. Flat anechoic response on or near axis should be the target.
How much the first reflection and sound power anechoic measurements should differ from flat is the area of dispute. And as I said, in a larger room where the first reflections are delayed by 10 ms or more from the direct sound, they may not matter subjectively nearly as much as in smaller rooms like mine where the first reflections are integrated into our perception of the tonality.
Perhaps I'm viewing things differently as I get older. I don't want to fiddle with frequency response so much from recording to recording. I want a set up which sounds great on most recordings with little fuss. I have no doubt that listening close up to BBC-type speakers toed in to face my ears in a well damped room--sounds great. I've used that set up many times in the past and it DOES sound great--most recently with the Harbeth M40.2 in my current room with the speakers only 55 inches from my ears. I think the "well damped" room part is more difficult to get correct in a small room like mine than in more capacious rooms, but you can get it right enough for great musical satisfaction.
I think people need to understand more about what the spin tests are and what they show. I suggest reading https://www.audioholics.com/loudspeaker-design/understanding-loudspeaker-measurements for an easy-to-follow explanation. The spin tests are meant to be done anechoically or with software (like the Klippel) which allows the measurements to mimic such conditions even though the testing is done in a real room.
These tests have much more universal application than JA's Stereophile measurements, for example. JA's measurements may only be relevant in his listening room. Other rooms obviously show much different measurements taken with JA's same technique as is sometimes evident when he compares measurements taken in his room with measurements of the same speaker taken in the reviewer's room.
