I have 2 on order on their way to me. Will he interedtjng to compare to the planet tech sfp.Stocks were Low when I was ordering.
I will definietly post my impressions bro regarding both of them.I have 2 on order on their way to me. Will he interedtjng to compare to the planet tech sfp.
They were new old stock. They were pulled out of some data company.hi Abyss Man
were you able to get them new ?
I can get as many as you want here in Europe , but all are used.
Is there any unease that these SFP modules can have such seemingly important, even make o[r] break, consequences? Particularly as some of the best seem to be no longer available? There's going to be an unending iteration of them going forward, meaning constant reevaluation... and suggests that the SFP is a weak link, even in these high end switches. Or is this all just part of the fun?
Hi Guys. Does anyone know if there is anywhere one can Buy these Finisars still? They seem to have vanished from the usual outlets.
I also got the finisar modules a couple of weeks ago that CKK recommend, when i tried them in my pink faun server, they would not work. To cut a long story short, i found the problem was at the pink faun end, it did not like the module. So i used the planet module at the pink faun end and the finisar at the EtherRegen switch end. The sound was better than both Planet modules.
I wanted to see what two Finisar at both ends would do, so I investigated the Finisar catalogue, and since the finding seems to be low power and industrial temp design Are best sounding. I found one that is still in production. So i ordered two of them, they arrived today.
while I can’t comment on the new Finisar (Gen 3) compared to Finisar (original recommendation by CKK), since i could not connect the original at both ends, but when i connected both the Gen 3 Finisar modules at each end the sound seems better than what i had, and the fact they were compatible with the pink faun Server.
So everyone who missed out on the originals Finisar or want to give these a go, try these new Finisar Gen 3 modules. I include the link to the full spec to the modules, as you’ll see they use less than 600 miliwatt, and temp of -40C To 85c. So if some people want to experiment, give these a go.
https://optical.communications.ii-vi.com/optical-transceivers/ftlf1318p3btl
