Yes, that kind of stuff@wil do you mean settings for the iPad itself? Generally, I think the guidance was to remove unused apps, and there was a post about Low Power Mode setting, as I recall. Is that what you mean?
Also set Low Data Mode.Yes, that kind of stuff
Pardon my simple mind, wil, but why do you want to disable the wireless network?I have my Router and DCD up and running. Limited listening time, but so far so good! I have done a bit of comparing wifi-to-iPad and wired-to- iPad. So far, the first impression is they sound the same in my system.
If I want to disable the Router's WIFI, where in the Router settings do I go to do so? I've searched all the different menus but have not found the "Disable Wireless Network" button.
And, if I do disable, is it just as straightforward to later re-enable the Wifi?
Thanks
Ok.Give it a try and see what happens, the DCD filters are pretty effective. Your powersupply should be able to provide ample current though, that Fritzbox might draw considerable power.
Ok.
@nenon: Would the SJ mini arc6 dc4 be capable to drive Taiko router, Taiko switch and a current fiber Fritzbox?
Fritzbox 5590 fiber needs 12V, 2.5A. At least that are the needs stated on the 5590 bottom.What is the power requirement of the Fritzbox? How many amps does it pull?
Test mag stated 18Watts consumption when downloading.
That’s an excellent question, Steve! For reasons that I can’t claim to be rational, I’d rather have as little Wi-Fi and Cell radiation as possible in my listening room.Pardon my simple mind, wil, but why do you want to disable the wireless network?
Yes, but ping me on PM, so we don't congest the Taiko thread.Ok.
Is there a post anywhere that suggests best settings when using iPad as Audio Remote only?
For those of those doing this, you may want to allow access to the router as well: to do this set a firewall rule to allow port 80. Thanks @nenon ! Here's a screenshot from him:@wil, or anyone else looking for the button to turn off or on the Taiko wireless broadcast:
Log into the Taiko router admin control panel.
Across the top of most pages are pull-down tabs, "Status", "System", "Services", etc. Click on the pull-down tab "Network"
Click on "Wireless" on the pull-down menu. On the window that opens, Click on "Edit" (circled in red):
The button to toggle the wireless broadcast on and off is in red:
Hope this helps.
Steve Z
Could these Roon settings have any effect on XDMS?
Hi Kris,
Sure they do for both . Mainly Roon , a little bit on xdms.Could these Roon settings have any effect on XDMS?
Great point Steve !Hi Kris,
I looked over the URL you posted -- all good info for Roon settings but it does not mention best settings for iPad used as an audio-only control device. For Emile's advice:
My slow mind this early in the day thought the same. Fortunately for me my iPad and router are in the same room . Thanks for clarifying David as the Router questions and answers were well above my pay grade.www.whatsbestforum.com
Post 19,179 in this thread.
Steve Z
so here's a test and all FWIW . I am sitting outside in my backyard typing this post using Taiko Wifi with my laptop. I read with interest what everyone is doing with their router. I have done nothing to mine except "sign on"
Only things on this network are, Extreme, iPad and MBP.
I have zero issues with driving my XDMS app wireless from here and playing music upstairs. Sounds great to those upstairs in my sound room . So similar in my sound room, I have always used my iPad wireless and zero issue.
Are all of you doing this because of very busy networks in areas where you live. I see no reason for me at least to be messing with my router
YMMV
I don’t transfer files wireless We’ve had this discussion. However Im totally lost trying to understand why users are hearing changes sonically if your iPad is used wired vs wireless. If this really occurs we should be able to pick it out listening blinded If we can’t then the sonic differences are insignificant. At least that’s how I understand it
...I'm lost why people hear differences with the router in the workflow and they're only playing local files. A riddle wrapped in a mystery.inside an enigma.However Im totally lost trying to understand why users are hearing changes sonically if your iPad is used wired vs wireless.
