does the WIFI chatter inside the router actually stop when you just disconnect the antenna?
What chatter? The SSID broadcast? That really has zero effect…
This is all in progress. We are expecting a new enclosure batch shortly, but we cannot currently provide an accurate estimate because 3rd party deliveries have come up short lately. Please see my previous post for a more in-depth explanation.Estimated delivery for the rest of chrome routers &dcds?
...and I think recent discoveries were, the noise to worry about was not the airborne WiFi, so perhaps in the case of the Taiko router design and implementation, WiFi "on" doesn't matter...which is why you guys decided late in the product dev cycle to add it to the device in the first place.
I was thinking about the activity of the hardware 'frantically trying to connect' when WIFI is on, yet; what apparently does not matter , does not matter ;-)
Indeed, activity from connected devices matter though, but without an Antenna, there are no connected devices
“traffic processing” on the Wi-Fi receiver creates less noise then on a RJ45 (wired) connection due the lower power consumption. If you can actually hear that is a different question
In order of “traffic caused” noise the ranking from lowest to highest is:
1) DAC
2) Wi-Fi
3) RJ45
4) Fiber
I did a lot of testing with Buffalo switch and it is still beneficial to use it between the home router and taiko router. It is a must to have In my system....but what about this "spread spectrum" concept Emile noted from stacking switches, @Kris ? You are the Switch Meister, with PFBuff still in the flow, right? I put mine back a week ago myself after a long absence. What do you think?
In my case, Roon does not find the Core from my home Wifi or tells it to look for another Core.Yes you do indeed need to do that.
Is there a way to look in the router configuration to see if it is a configuration problem?
Thanks for sharing this insight. On another forum, an individual reported that his server's sound quality kept degrading after 2-3 days, with a reboot helping to restore the sound quality. I referenced your post and that lead him to find that the ground leading to his system was defective. Addressing this seems to have resolved his problem. Seems to confirm that charge buildup was what was causing the sound quality degradation.What it is, or rather how it’s best described, is some kind of charge buildup, over time it can start affecting sound quality. What it is exactly we don’t know. We do know it accumulates in large conductive masses. There are grounding tweaks creating a high affinity for this, if you use silver for example, it’s more conductive then copper, and this “charge” “likes” to move there. Then there are mechanics to dissipate this charge, batteries for example. Connecting a battery negative pole to a highly conductive mass appears to be able to dissipate this energy. There are a large number of manufacturers using all types of techniques to address this. Electrostatic, electromagnetic, piezoelectric, electronic circuitry and/or “quantum technology” seemingly addressing this.
Powercycling components with large conductive masses once in a while is good practice, but if you have one of those “mysterious” grounding systems this can upset equilibrium aswell.
I think this galvanically isolates the very busy and hard working home router from clean Taiko system. Or it is reclocking with PinkFaun Ulta clock I have in Buffalo?
BUT I dont touch the Taiko router settings and Taiko Extreme settings.
I belive Emile had so much time to fine tune it To the best possible outcome that I can only mess all things . So no changing anything in Taiko products.
The only thing I can consider in the future is to turn the firewall off in Taiko router as I have it already on my home router. Not sure how to do it and if it makes sense.
I've already done it and still can't find it.Select “look for another core”.
By the way, it is normal that from the Taiko network I can access the internet, I thought that was blocked but in my case I surf the internet without a problem
For the sound quality it would be better if you browsed from the home Wi-Fi or it is indifferentYes that’s normal. It’s a router, functionally the same as your home/isp/internet router. It “shields”you from “the internet”, aka people on the internet cannot just access your devices, but it allows you to browse the internet.
I’m sure I haven’t tested as thoroughly as Kris, but my initial impression is that removing my PF/buffalo Router and connecting copper LanI did a lot of testing with Buffalo switch and it is still beneficial to use it between the home router and taiko router. It is a must to have In my system.
