me too.Is the area you are configuring the tab in the lower left-hand corner that says “load defaults”?
I am afraid to touch that button for fear that it will reset all my settings back to default.
Its been referred to as Audio Nervosa.....the angst that you may not have the optimum setting and are therefore somehow missing out on some sonic absolute which puts you in a state of constant analysis. Horrible.....Just finished another deep dive with a variety of material. It certainly is material dependent to a degree. But after a while, finding the setting that provides the "musical truth" is like watching Kurosawa's Rashomon and trying to figure out whose version of the story was most truthful. Just pick one and close the damn control panel or you will go nuts! (I'm still a 3 but 7 almost had me at times if it weren't for the bass.)
I've spent 7 years getting my Zus subs settings just right. Another 7 years on this? Um...
You guys wanna get Bass and Treble controls, and a Loudness button. Graphic equaliser maybe Lol.
I tried 3 yesterday...for me it was bright and a bit thin
5 just snaps into place so obviously in my system, it's not subtle at all....
Maybe Emile could negotiate an acquisition of the 2 channel rights with Roon?I was told by an industry insider that Roon Labs fired it's "2-channel guys." In particular, he cited Steve Silberman and Bill Leebens. Roon is apparently moving to focus on "Home Integration." Think speakers in your bathroom and thermostat controls.
Sound's like bad news to me and perhaps a explanation for the latest software release sq problems.
Emile, lead us to the Promised Land!
I thought Leebens worked at PSAudio.
Greetings,
Here is the Ubiquiti X- SFP router. I must warn you, I bought one about a week ago and got so frustrated with trying to set it up with my Verizon Router that I stuck it in the box and returned it.
Then I was mad at myself for giving up and ordered another one. It only took an hour to install, but I could not figure out how to eliminate the conflicting IP addresses between the Verizon router and the Edge router. It was just me. Anyone familiar with networking would have done it in 15 minutes.
https://www.ui.com/edgemax/edgerouter-x-sfp/
I am using the SGC LPS. I know there are more elaborate LPS's available but for $160 the SGC does a great job. I could tell the difference when I added it to my Verizon router.
You need the 12V version for the Edge router.
https://www.smallgreencomputer.com/collections/accessories/products/5v-15v-linear-power-supply-15w
If anyone goes this route and has questions about setting up the Ubiquiti Edge let me know, I now can either answer any questions or at least point you in the right direction, which is exactly what Al and Roy did for me.
Did you get the LPS for the Edgerouter. How much power does the LPS output? It's says 24VDC
I have the JCAT Optimo 3 Duo LPS connected to one of the JCAT Gold Switches. I also have it connected to the Edge router as the Optimo has dual outputs.
The Edge router works with I think it's 5V?? to 24V. The JCAT Optimo is feeding it 12V. Someone else mentioned they are feeding the Edge 15V.
How does a 12V LPS fare with the Edgerouter? Its requirements state 24VDC. Have you had any issues with an underpowered LPS?
No worries. Thanks to you, my homework is done ;-)Scared the heck out of me
I went back and looked at this spec sheet and it shows the X uses 12V, but the XFP can use 24V with PoE as Octaviars just stated.
https://dl.ubnt.com/datasheets/edgemax/EdgeRouter_X_DS.pdf
I got lucky because I know that I looked at the X specs instead of the XFP when I ordered the LPS at 12V, which does work fine.
