That is a dangerous statement -- "someone who knows what he is talking about. . ."May be create the playlist in Roon and play in TAS for now?
Edit: see previous post from someone who knows what he is talking about...
Steve Z
Thanks for that careful walk through! I had done precisely as you described, I thought, but I'm guessing at the last step to save I hit "Enter" on my keyboard, rather than clicking on the Save icon. This time I clicked on the icon, and there's my list, saved for posterity. Thanks, again!Build a queue from Tidal, Qobuz (when working for you) and your library in or accessed by the Extreme by clicking on "Append To Queue" from the three vertical dots next to a track (or album). When you have the queue built in TAS, click on the floppy disk icon at the top of the TAS window to save the queue as a playlist. Name the list and click on "Save".
To find the playlist go to the home window (in TAS' "Queue" view), click on "My Music". The last item on the list is "Playlists". Your new playlist will be there (along with any existing playlists from Qobuz and Tidal).
Hope this helps,
Steve Z
Hi Mike,over the last 2 days i've been listening to redbook only packaged playlists; very familiar territory and not sure what clicked in but i'm a bit stunned at the continual remarkable realism and live sort of presentation. i had a power outage Saturday night so needed to reload. i'm in new territory of digital enjoyment. these are files. not tried streaming. maybe the re-boot caught an update that i had previously missed?
not sure what i did exactly. or maybe it's just me and nothing has changed. i almost don't want to think about it too much. just ride the wave.
we will see how it sounds in a week or so. just thinking out loud in case others have been here too.
Mike and Edward,Hi Mike,
We have found that a lot of digital gear benefits from a periodic reboot after power off for several hours
As always YMMV, our evidence is anecdotal. We do have some plausible explanations about how a reboot can help SQ ;-)
Hi Emile,Beside all the usual explanations, there is an effect to which there is no direct explanation. There are a lot of products on the market attempting to address this, or working with the phenomenon, perhaps attempting to curb this into an advantage. These are the so called "grounding tweaks". Fact is I regularly get confronted by people observing a degradation in system clarity over time and I have had several system setups "suffering from this condition" myself. Often it can be remedied by powering off a single system component after a certain time duration. The component is variable, the time duration is variable. It can set in after a few hours, but it can also take weeks. The more complex the system, as in the more boxes, the higher the risk of running into this. I have had this for a while with my Totaldac, consisting of 8 boxes, that would benefit from a once a week power down over night. But it's not the Totaldac as in another setup I had the same thing going on with my Stern/Heisenberg pre/power amplifiers, which I could leave powered on for 2-3 days tops before a reduction of clarity started setting in.
For entertainment value I will share an experiment I ran around a year ago. For those familiar with our Daiza platforms, it's footers utilize a round copper disc which have no electrical conductive path to the equipment placed on top, nor does it have a path to "ground" as it's situated in between non conductive Panzerholz on both sides. If you ground these copper discs, it is very noticable, in fact it is as noticable, and similar in effect, as connecting an additional groundlead going to a grounding device or safety earth from your equipment chassis ground. Do note, again, this is just a copper disc, without any electrical connection to your system. If I connect these discs to safety earth, it has an initial positive effect, but it does turn negative after a variable amount of time, typically over a period of 4-5 hours, which can be remedied by disconnecting the groundlead for 30 minutes or so. Interesting to note here is that in this case it does not seem to matter much which type of equipment is situated on top of the Daiza. If I lowpass this groundlead with a choke, the positive effect only lasts for 20-30 minutes after which it turns negative. Connecting a "groundbox" to it lasts longer, between 1 and 2 weeks. This is simply hard to explain but it indicates there is something like perhaps a static charge build up phenomenon caused by mechanical friction, I am playing with this from time to time but I have not come up with a clear explanation nor remedy. It's an X-file!
Hi Emile,
Are these static charge buildup removal effects similar to what the “Irrational Bur Efficacious” test CD by Ayre does by playing a glide tone? The CD is recommended for enhancing system burn-in and for periodic maintenance.
Keep riding the wave Mike! Most interested in hearing your thoughts on how your current digital experience compares to its recent past. And perhaps after you’ve had a little more time to digest the new digital wave, your revised assessment of how it compares to your SOTA vinyl.
I agree digital and vinyl are never going to sound exactly the same, just like tape and vinyl don't sound exactly the same.Not trying to answer this for Mike, but I don't think vinyl and digital will ever "sound" the same. For me personally it's irrelevant as the music I enjoy listening to most sounds better to me on a digital playback system, I just prefer how digital "soundstages" and how it renders the frequency extremes. I have heard a few of those special analogue cuts which have this midrange translucency you will only get from those. To have that on digital something will need to change in the transfer / recording / mastering process, and that will then probably remain limited to a select few cuts, if it ever happens. Unless we can remediate prior "errors" made, never say never.
I use this anti-static gun on my cables, Tripoint grounding box, and general area of my equipment before critical listening. Helps in the cold and dry Chicago winters.Beside all the usual explanations, there is an effect to which there is no direct explanation. There are a lot of products on the market attempting to address this, or working with the phenomenon, perhaps attempting to curb this into an advantage. These are the so called "grounding tweaks". Fact is I regularly get confronted by people observing a degradation in system clarity over time and I have had several system setups "suffering from this condition" myself. Often it can be remedied by powering off a single system component after a certain time duration. The component is variable, the time duration is variable. It can set in after a few hours, but it can also take weeks. The more complex the system, as in the more boxes, the higher the risk of running into this. I have had this for a while with my Totaldac, consisting of 8 boxes, that would benefit from a once a week power down over night. But it's not the Totaldac as in another setup I had the same thing going on with my Stern/Heisenberg pre/power amplifiers, which I could leave powered on for 2-3 days tops before a reduction of clarity started setting in.
Hi Emile,Not trying to answer this for Mike, but I don't think vinyl and digital will ever "sound" the same. For me personally it's irrelevant as the music I enjoy listening to most sounds better to me on a digital playback system, I just prefer how digital "soundstages" and how it renders the frequency extremes. I have heard a few of those special analogue cuts which have this midrange translucency you will only get from those. To have that on digital something will need to change in the transfer / recording / mastering process, and that will then probably remain limited to a select few cuts, if it ever happens. Unless we can remediate prior "errors" made, never say never.
For me dragging vinyl into my the conversation is very relevant. Not in the context of which sounds better. I think we all agree they always did and always will sound different. Different people will always have different opinions on this topic.thanks. it seems that right now there is a degree of realism not previously ever experienced with digital, a depth and the music actually living in space. i suspect that it's related to subtle improvements in phase and timing somehow. that flat-ish type digital sound where all the boxes are objectively checked but something is lost in the translation; at the moment the sound has broken free from that feeling. certainly this is a matter of climbing up the scale of things and at particular points new things are revealed. not an all or nothing proposition.
does that make sense? like i said above, i really don't want to analyze it, just enjoy it.
OTOH let's not drag vinyl into it. i've recently pushed my vinyl higher too......as i optimize each of my turntables there are musical secrets i'm hearing for the first time (as i'm sure others have heard, and more). digital is not playing in this same realm. yes, it's also different.....but it's more than just different. on Sunday i was flying high with the digital, then did vinyl for a couple of hours. it was a different level. but i was still delighted to return to the digital later. i loved all of it.
Until you hear the Extreme with TAS and with the new usb driver you have not heard what is possible from Taiko audio from a sonic perspective. As well as much more to come. For me it's a paradigm shift.Bob, I've listened to Extreme twice now. In a system that previously ran the SGM for 4 years, a really nicely optimised tubes/horns setup, with a superlative dac.
And that 4 years made as good an advertisement for streaming as I was likely to come across, even w material that had variable mastering quality, like a lot of 70s and 80s prog and fusion.
So I've now heard the Extreme twice, and it was instantly recognisable as a very different transducer from the SGM. Way more deeply resolving, frankly scary good dynamics, and seemingly a fathomless noise floor (better than the already-excellent SGM).
But, boy oh boy, was it trying with a couple of random mid-70s albums that I know for a fact despite not being stellar on LP or CD (original master) are very listenable indeed.
It kinda reminded me of highly-strung analog using potentially unforgiving (of poor setup) cart, and tt/arm optimisation.
Because after a lot of attention to detail (incl fibre optic, and crossover changes in the spkrs), the Extreme was way more appetising second time around. But still with this tendency for forensicness on poorer masters (where SGM sailed along more serenely).
It's gonna be this I'll listen out for as an area of improvement, plus all the good stuff sounding even better, when I next hear Extreme, now w TAS and USB driver.
