Ok thanks - will give it a try...It is support@taikoaudio.com but i have written a couple emails there with no response.
Why should you not use 3 re-clockers? Because at some point multiple re-clockers may cost more than upgrading your DAC. There's a point of diminishing return.I have 4 of them only.
But friend of mine is selling 2 standard Buffalows so I will get them soon.
As far as I remember Nenon tested upto 6 of them and they were still better Than 5.
So you might be on a good way if you are thinking to get 8 or 24 of them.
I suspect it is like reclocking. I have 3 TotalDAC reclockers . I can play with 1 but why should I if with 3 is better ?
Thanks again Steve! Have updated playlist. People can now return to tech talk and cruelty to woodchucks with music.Hope there are some selections folks like.
Steve Z
The simple reason is I cant upgrate my DAC any further !Why should you not use 3 re-clockers? Because at some point multiple re-clockers may cost more than upgrading your DAC. There's a point of diminishing return.
A somewhat relevant analogy is the guy that continually upgrades his speaker cables to the point where they cost $20K while his speakers cost $4K. Which do you think sounds better, $20K speakers with $4k SCs or $20K SCs with 4K speakers?
Apologies Gentlemen,It is support@taikoaudio.com but i have written a couple emails there with no response.
A reply to your email has been sentOk thanks - will give it a try...
I noticed yesterday that Qobuz favorites are showing up with my local music in TAS. Is this new? I don’t remember seeing it before.
You can enable/disable that in the "online library integration" plugin.
Where can I find that?You can enable/disable that in the "online library integration" plugin.
I don’t recall changing that setting which is why I am wondering. I do see that plugin is enabled.
Either way, this is great.
Most of us just turn to the Netherlands and quietly whisper "Hey Emile, are you there"? and a few minutes later, he magically appears on TeamViewer.Hey guys - does anybody know the Taiko 'help' email to assist with trouble shooting?
Most of us just turn to the Netherlands an quietly whisper "Hey Emile, are you there"? and a few minutes later, he magically appears on TeamViewer.![]()
does anyone here have experience with using the emm labs da2 v2 as a dac with the extreme?
