maybe those gadgets add some "favor" or "noise" into my system chain but very pleased to our ears.
I'm curious how that is remotely possible? I'd be curious to see if you have someone plug and unplug the cable out of your sight whether the same results occur.Hi Taiko team
Tried a few tunes and unplug the lan cable while playing in TAS
Confirmed my extreme sounds much better with the Lan cable plugged in, it's more airy, open up the sound stage, more details and 3 dimensional, the difference is very significant,
Thx,
Joe
I posted yesterday and last evening Emile was already got into my Extreme searching for the root of problem, before this I did clean up those strange alphabets/characters in album titles, sound tracks etc but didn't work, Emile went deeper into the titles inside the ID tag, also shorten one of the album's title length, in the end he recovered 2 albums in 30 min or so.Hi LR319,
HDTT does indeed use some characters in several albums which are not supported by LMS, I can connect remotely and show you if you'd like.
If you add multiple tracks to the playlist queue you can then play the whole queue.
The all new, LMS free, scanner engine will digest ID tags tags like this ;-)I posted yesterday and last evening Emile was already got into my Extreme searching for the root of problem, before this I did clean up those strange alphabets/characters in album titles, sound tracks etc but didn't work, Emile went deeper into the titles inside the ID tag, also shorten one of the album's title length, in the end he recovered 2 albums in 30 min or so.
Top notch customer service, kudos to team Taiko.
It should show up in TAS but then again there are other criteria to meet with the current TAS/LMS, easiest way to find out is to open TAS and see if its there.All my files from the same CD are located in a sub folder with a file named cover.jpg that house the cover photo. Will that be recognized by the new engine as well?
Sure is a standout in Silver.
Hi sbo6I'm curious how that is remotely possible? I'd be curious to see if you have someone plug and unplug the cable out of your sight whether the same results occur.
Understood Joe but again - I'd be curious to see if you have someone plug and unplug the cable out of your sight whether the same results occur. How connecting to a switch and the ethernet port of the system would remove any noise to an already cached and playing file goes against logic IMO. In any case, enjoy!Hi sbo6
Tired few times already and my even my mum can easily tell the difference, that ethernet cable is connected to my whole network chain which those gadgets may 'remove some noise' or "add some favor" to my system chain, but its very significant and pleased to our ears, i really don't know how it works but if the taiko switch can further enchance the sould quality that means upstream components still affecting the performance,
I will try to arrange a home demo for the premap with the Taiko dealer in HK, i will find him to join this test and try to record for you guys reference, the ethernet cables im using are quality bulit and lots of the hifiers in HK are using, the performance uplift is proven
Again, the delta is not that significant when compare with using aurender as the source, and obviously Extreme is much better than aurender to minimise the upstream dependences
Thx
Joe
Hi Sbo6Understood Joe but again - I'd be curious to see if you have someone plug and unplug the cable out of your sight whether the same results occur. How connecting to a switch and the ethernet port of the system would remove any noise to an already cached and playing file goes against logic IMO. In any case, enjoy!
Hi Gents
Just tried to change the songs in the taiko audio app in my ipad but it suddenly shows the "taiko audio beta has expired"
Any suggestion to fix it? Rebooted the ipad and same message popup,
Thx
Joe
Thx buddy, i will go back unto test flight and update the new version tmwGo back into Test Flight and download the new version which extends the expiration date.
For some reason, for some Beta Testers, the option to update does not appear.Go back into Test Flight and download the new version which extends the expiration date.
These unlucky ones can go to this URLwith their Apple device
TestFlight - Apple
Using TestFlight is a great way to help developers test beta versions of their apps.testflight.apple.com
Yes, that new engine is 100% our code, we can make it do pretty much everything we want, except making coffee.
