Why no coffee?
Even the earliest desktop PCs had a coffee cup holder that slid out
I know you are joking but...
Why no coffee?
And there are ones that make coffee as well...
Looking at the copper plumbing supply inside the extreme, the parallel to the internals of an espresso machine are obvious.And there are ones that make coffee as well...
More detailed info & the manual are here :Hello Taiko Team,
I saw that SOtM has released an interesting network board sNI-1G: https://www.sotm-audio.com/sotmwp/english/
Seem to be someting to test with the Taiko...? Has anyone tried it yet?
https://audiophilestyle.com/forums/topic/19715-hq-player/page/735/?tab=comments#comment-1079360why don't you also develop the possibility of upsampling in PCM up to 3072 mhz? .....
is that possible?
http://blog.livedoor.jp/johnny_trio_lsr/archives/2253780.htmlOn Linux and macOS you can already do it if you manually adjust the configuration file. But it goes to same category as DSD2048 that there are no DACs that would have such input possibility on the market right now.
https://www.kitsunehifi.com/product/holo-audio-may-dac/?????PCM?3,072kHz???DSD?2048(90/98MHz)???????????????????????????????????????????????????????
http://www.audio-gd.com/Pro/diy/DA8/DA08EN.htmTheoretically it can do DSD2048 and PCM 3.072Khz however is untested at this time.
Support up to 24 BIT / 3072Khz in NOS mode
If it says you're on 3014, then that's the 768khz version. If you're on 3012 then it should play 1.536mhz fine.
take note version 30.14 are for those with either JCAT Femto PCI-E card (renasas chipset) or the Matrix Element or Element H card (texas instruments chipset)
these are LIMITED TO DSD512 and PCM768 at this time.
MOST COMMON upgrade firmware - version 30.12 is for motherboard USB chipset which is commonly Intel base USB controller and should support DSD1024 and PCM1.536Mhz as stated above in overview.
Thanks for going to all the trouble to post this. Though I don't anticipate transferring Roon core to my Extreme again (since I've only used it once or twice since TAS player landed), I have definitely filed away the pdf file for future reference.FYI - For those that might be transferring their ROON Core and ROON Library to the SGM Extreme and are having difficulty getting the old playlists across, here's how I ended up having to do it. Hope it helps. Wish there had just been a playlist file to copy over, but I sure couldn't find one.
You are welcome. I used Soundiiz to transfer Tidal over to Qobuz as well, but I could not find a way to move the ROON playlists from one library to another - seems a Playlist file would exist and transfer as well (as Meridian used to have), but no such luck in my search.Thanks for going to all the trouble to post this. Though I don't anticipate transferring Roon core to my Extreme again (since I've only used it once or twice since TAS player landed), I have definitely filed away the pdf file for future reference.
I wonder if Soundiiz would work for this? I used it to transfer my Roon and Tidal playlists to Qobuz and it was pretty easy, with the caveat that if the platform a playlist is being transferred to doesn't actually have a specific track available the new playlist won't be 100% identical.
I appreciate the work you put into this.
Steve Z
An interesting piece of news is there is now a Bay Area Users Extreme Users Group. There is also a User Group in SingaporeYou are welcome. I used Soundiiz to transfer Tidal over to Qobuz as well, but I could not find a way to move the ROON playlists from one library to another - seems a Playlist file would exist and transfer as well (as Meridian used to have), but no such luck in my search.
V2
If I may ask - how long did the process last? Obviously, it depends on how big your playlists are, but I would be grateful for a real-life exampleYou are welcome. I used Soundiiz to transfer Tidal over to Qobuz as well
Talk to us Ed. This looks very interesting technologically and price wise. Have you (or anyone else) heard it, and in what system?A pretty interesting USB converter is being added to the Taiko Audio USB 5.2x Driver
It is the Mutec MC-3 +
Hi AMR -If I may ask - how long did the process last? Obviously, it depends on how big your playlists are, but I would be grateful for a real-life example
Folks -FYI - For those that might be transferring their ROON Core and ROON Library to the SGM Extreme and are having difficulty getting the old playlists across, here's how I ended up having to do it. Hope it helps. Wish there had just been a playlist file to copy over, but I sure couldn't find one.
Perhaps best to print out the pdf instructions, attached.
It's going to take at least a week to get some feedback. This MC-3 is feeding a Tidal CamiraTalk to us Ed. This looks very interesting technologically and price wise. Have you (or anyone else) heard it, and in what system?
Has it been tried with any TotalDAC systems?
Apologies for not being clear enough - I meant Soundiiz process and was curious about your user experience when it comes to transferring. I got precisely what I wanted, so thank you for reading my mind properlyHi AMR -
I assume you meant the Soundiiz process, converting from, say, Tidal to Qobuz? I started doing it manually (for a friend) and it was insanely painful. Then Ed suggested Soundiiz and it was immensely more efficient - just a matter of minutes (mostly just getting familiar with it).
