I have a few Setchi devices in my main room as well.I would be curious what Emile’s @Taiko Audio current view is on grounding boxes with the Extreme.
I doubt there’s a universal right and wrong with grounding boxes….it probably depends on the way the system is connected, how all the individual components are grounded and the quality (impedance) of the ground connection itself.I am not against it but when I tried it, it made things worse. I tried it on all my front end gear.
Agree 100%. System dependent.I doubt there’s a universal right and wrong with grounding boxes….it probably depends on the way the system is connected, how all the individual components are grounded and the quality (impedance) of the ground connection itself.
I had the Entreq importer bring an assortment of cables and boxes to my listening room for evaluation and the only place it made a small difference was with the network switch, which has a 5V DC LPS while all Ethernet cable screens are star earthed to a low impedance ground. I left everything connected to the Entreq boxes for a few days then disconnected one box at a time while listening for any changes, but again the only minor change was with the ethernet switch, which is otherwise ungrounded.
An earth cable from the switch’s chassis ground point had the same effect.
I also agree. Not only system dependent but dependent on how your electricity supply is set up at home. Anecdotal evidence from this side of the pond would suggest that apartments seem to have more benefit that houses.I doubt there’s a universal right and wrong with grounding boxes….it probably depends on the way the system is connected, how all the individual components are grounded and the quality (impedance) of the ground connection itself.
Every opinion is very valuable . Thank you !I am not against it but when I tried it, it made things worse. I tried it on all my front end gear.
We don't want to publish here how we do things but PM me if you wish to get more of an idea what we do by having a callDoes the Extreme send to cache using streaming radio or Qobuz?
Marc
Few early impressions from the HRS VXR rack. Previously, I had tried a few footers under the Extreme (though still on the glass shelf). The footers improved the sound by getting rid of some nasties while also improving other aspects, but they also changed the overall tone of the sound. This might work well in many systems.Looking nice - - please share your sonic impressions from the change!
Thanks for sharing! So, do I understand correctly that you're listening through headphones only? When you mentioned the bass improvements particularly, I was thinking to myself how nice it is that a good rack can address feedback loop stuff - - but with headphones, that shouldn't be an issue, so the rack's influence goes beyond that. Very interesting!Few early impressions from the HRS VXR rack. Previously, I had tried a few footers under the Extreme (though still on the glass shelf). The footers improved the sound by getting rid of some nasties while also improving other aspects, but they also changed the overall tone of the sound. This might work well in many systems.
With the HRS VXR, the sound has improved in almost every aspect, but the tone remains the same. I now understand what others meant when they said, “The HRS rack has no sound”. This is exactly what I was looking for since I have the tone pretty close to where I want it. In comparison, and based only on long memory which is not very reliable, but I remember the footers sounding a bit smeared in the upper frequencies compared to the HRS. At that time, my system benefited from that little bit of smearing.
The sound is not only calmer now, but also more lively. Instruments have taken another step (or two) up towards realism. Bass improvement was the first thing I noticed.
I’m currently waiting on a Stromtank to be delivered next month so I’m getting by with plugging directly into the dedicated outlet. Since getting the rack, this is the first time I have found my system engaging without any power conditioner/supply. I am definitely missing some big benefits to the sound that I heard when I had the S5000 HP in for demo so the combo of the two should be a nice uptick. Hard to believe, but the S5000HP was leaps and bounds ahead in dynamics compared to directly plugging into the dedicated outlet (headphone system only). Low level detail retrieval is not even a contest, but that's to be expected.
Edit: I always knew that vibration control had its benefits, but for some reason I always considered it more of a tweak than a foundational element. This rack has completely changed my mind on that.
Sorry Emile, I would love to but, I don’t have a Roon account anymore nor Roon installed so I can’t use my Renderer v2.Apparantly the video is about not hearing a difference between the interface used from Extreme to MSB Select, Ethernet (Renderer v2) or USB (USB Pro ISL). That could be possible since the last OS upgrade, any other MSB owners willing to try that out to verify?
Both work fine.Have any of you added your own extra storage to your Extreme, and if you have, did you buy the Asus Hyper card Gen 4 or v2? Both are available and both hold 4 m.2 cards.
This is a valid observation and I understand what you are describing in terms of relative differences as I have also experienced such differences in the past and present when comparing USB to AES/EBU (with non--Taiko gear). The thing is that USB is highly reliant on the implementation and quality of the interfaces on both ends. I can't speak for Nagra as I have no personal experience with the brand but I do know that the USB interface on the Extreme is built to relay the best sound quality possible, both technically as well as musically. The large majority of users seem to agree but don't let that discourage you! I always advocate for anyone to use the connection method that works best according to their own ears. If it sounds great, don't worry about it and enjoy the music!Finally achieved 400+ hours on both my Shunyata Omega USB and AES/EBU cables, both the same 1.5 meters in length, between my Taiko and the Nagra HD DAC X. In my system, and in my judgment, the AES cable clearly outperforms the USB cable, being more musical and organic, with both more substance and fluidity at the same time. The USB cable can be more "detailed", but, with the types of music I listen to (classical and jazz), that was not an advantage in most cases.
Have you tried different USB cables? I am using Sablon Audio Evo which outperformed my previous much more expensive usb cable. It sounds very life like, full with emotion. Maybe you just need to try one I guess I am not the only one using Sablon here.Finally achieved 400+ hours on both my Shunyata Omega USB and AES/EBU cables, both the same 1.5 meters in length, between my Taiko and the Nagra HD DAC X. In my system, and in my judgment, the AES cable clearly outperforms the USB cable, being more musical and organic, with both more substance and fluidity at the same time. The USB cable can be more "detailed", but, with the types of music I listen to (classical and jazz), that was not an advantage in most cases.
