Now you’re killing me. The wait is not good for all of usSome Eye Candy for Extreme Owners who like to use their Smartphone to control their Extreme
Looking good!Some Eye Candy for Extreme Owners who like to use their Smartphone to control their Extreme
This is on the list of functionaltiesEd
will the user be able to control the player progress bar so that we can fast forward to a piece of the song by using a finger to move the bar
You can still use Roon to find the pieces, then XDMS to play them (should this functionality not be present In XDMS).Nice!
I take this opportunity to ask you a question about XDMS features.
I'm Roon user.
The main reason I chose to use Roon is classical music.
Roon is able to recognise (I don't tag the files myself) an album containing several compositions by different composers and arrange them in a consistent way.
Everything is automatically tagged with :
- Composer
- Composition
- Movements
- Ensemble
- Soloist
- etc.
And the coolest thing is that it is able to recognise the same composition from the same composer across the entire library.
I especially like the latter feature.
I can, for instance, compare different interpretations of the first movement of Tchaikovsky's Violin Concerto in D major, Op. 35.
A click shows them all.
Will XDMS be capable of something similar?
I actually use Roon on a Nucleus server for the rest of the house, but it isn't involved with my main system at all. But, I often will run it parallel with TAS just to get this exact alternative performance info. A tad annoying, yes, but I get the best SQ available to me now, and still get the knowledge base for navigating. And my wife loves Roon for the Kitchen, Living Room, and Porch systems and devices.You can still use Roon to find the pieces, then XDMS to play them (should this functionality not be present In XDMS).
As a big fan of Oyaide C-004, I can testify to this! While there will be those who favor the sound of the Furutech and those who prefer the Oyaide 004, there's no denying that there is a large sonic difference between them. And this can be heard with every component that I tried so far. Have to confess that I was unaware that there was an 004 in the Taiko but glad to know now!Just replaced the IEC cable connector that plugs into the Extreme. I had been using a Furutech FI-C15 NCF since I got the Extreme around two years ago. Changed to an Oyiade C-004 IEC which was designed to match the IEC inlet that is on the Extreme (same manufacturer, same plating).
The Extreme is on its own dedicated circuit using a Gigawatt circuit breaker and twelve feet of Gigawatt wire terminated with the IEC connector plugged directly into the Extreme (no outlet or separate power cable).
The Extreme was powered down for a little over half an hour while I replaced the connector. I powered it back on and continued playing the same track that I was playing before the swap.
I expected to have to struggle to hear if there was any difference at all in sound. Instead, I was totally blown away by how much better the Extreme sounds with the Oyaide IEC. Not subtle at all. Better, more articulate bass, better dynamics, more details and totally natural sounding. This is even before the Extreme has restabilized after being turned off. Just amazing what I have been missing for the past two years!
The Oyaide C-004 IEC connector works wonders here! It seems to follow the voicing that Taiko did when they picked that Oyiade IEC inlet for the Extreme. Very synergistic.
Filetype, bit depth, and sample rate are also, as Ed puts it, on the list of functionalitiesUh oh, that may be alot to ask.
Personally I am just hoping to see the file resolution on the primary screen when streaming instead of TAS always showing "750kbps, FLC" until I click through "More Info" to find the album's resolution etc.
Rest is gravy for me given the SQ boost. I imagine additional features may be rolled out over time so XDMS can be released sooner than later. Above specific request aside, I definitely would prefer a simpler initial offering than waiting for a software that includes everyone’s wishlist.
So many requests, expectations and pressure have already been applied. Release the beast (waiver signed)...
On the roadmap is identifying local music files using external database services so that we don't need to rely solely on embedded tags. This should go a long way toward organizing the library and making it search-friendly. Roon-like deep-linking functionality might be a possibility later but it is not on the radar right now. ATM, we're focusing on getting the core functionality ready for release.Nice!
I'm Roon user.
- Composer
- Composition
- Movements
- Ensemble
- Soloist
- etc.
YesWill there be a restart and shut down option via XDMS?
Marc
We have a very detailed roadmap and a clear definition of what we want. At this time, I cannot get into the specifics but as we go along, bits will be revealed, as Ed has been doing all along.Did you already fix the functional scope definition for the first release candidate of XDMS and is this something you could share with us?
1001% agree. I'm probably at the far end of the spectrum that just wants it sound great, look great, have a streamlined functionality and be rock stable. I don't need another Roon and all it's complex options. -- but I know there is pressure to do so.Rest is gravy for me given the SQ boost. I imagine additional features may be rolled out over time so XDMS can be released sooner than later. Above specific request aside, I definitely would prefer a simpler initial offering than waiting for a software that includes everyone’s wishlist.
