Thank you.A DAC inside the Extreme with a analog output to feed a preamp.
Tomas, which module of MSB are you using in the DAC? The SPDIF module of MSB DACs have two inputs: rca, the digital electric, and Toslink, the optical digital.I apologize but i may have mixed up my terminology of the input i was using. based on the sample rates supported i believe i was using the optical input of the spdif module and not toslnink as i was playing 192khz pcm without issue. thank you very much for the clarification and information about the best input from the taiko.
For my testing i was using the proisl usb, renderer and spdif module which has the coax and optical with word clock. in regards to my comments about the oladra sounding better over toslink than usb, i was using the optical connection of the spdif module which was why i was saying i was using toslink. but i was streaming all 24:192 pcm without issue. So at this point i might be slightly confused as to what terminology to use for the cable that puts out the little red light lolTomas, which module of MSB are you using in the DAC? The SPDIF module of MSB DACs have two inputs: rca, the digital electric, and Toslink, the optical digital.
Then, It’s Toslink you were using.For my testing i was using the proisl usb, renderer and spdif module which has the coax and optical with word clock. in regards to my comments about the oladra sounding better over toslink than usb, i was using the optical connection of the spdif module which was why i was saying i was using toslink. but i was streaming all 24:192 pcm without issue. So at this point i might be slightly confused as to what terminology to use for the cable that puts out the little red light lol
That's what i originally thought but didn't emile say its capped at 96khz?Then, It’s Toslink you were using.
thank you for clarification.96KHz is the standard but there are some solutions which can support 192KHz (it’s essentially just spdif).
Indeed, please, take a look at MSB webpage, SPDIF module specs.thank you for clarification.
To summarise:
-SPDIF / AES/EBU / Toslink is clocked by the source
Go to Discord and at controlapps you have your windows app update to download.OK, here's an odd question. I keep getting email notices to update my iOS app for XDMS, and I do so on my iPad. However, I mostly control from my Windows 10 PC, and I don't get update notices there. Is there an update path for the PC that I'm missing?
OK. I haven't been so in accord with Discord.Go to Discord and at controlapps you have your windows app update to download.
OK, I’ve sent you a Discord invite by DM.OK. I haven't been so in accord with Discord.![]()
I also have not been on Discord. How do I get "invited"?OK, I’ve sent you a Discord invite by DM.
The last app version is V53.
All set now with Version 53. Sadly, I see that it stops music playing when you clear the Queue, which the earlier version I was on did not. Bummer, as it is handy to do so when you want things to stop at the end of the track
You should install the last scanner-build too. At Discord you will get all the help you’ll need.All set now with Version 53. Sadly, I see that it stops music playing when you clear the Queue, which the earlier version I was on did not. Bummer, as it is handy to do so when you want things to stop at the end of the track playing.
Invite sent by DM.I also have not been on Discord. How do I get "invited"?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
