Lol, that's exactly what I said. Emile loves that kind of talk.![]()
I was not aware of that. Fortunately his products are explained by classical physics ...
Pretty sure that was sarcasmI was not aware of that. Fortunately his products are explained by classical physics ...
If you do a search on Sablon, they have been discussed roughly 201 times on this thread.Yes, there are a few of us with a Taiko setup who have purchased the QSA-Lanedri Ultimatum speaker cables. At 4/0 AWG, these speaker cables are the most massive commercially available speaker cables I am aware of and most capably manifest the effects of QSA's treatment. Their impact is nothing short of mind blowing but this is not the place to have this discussion.
AFAIK, Aurender has only announced that they will add Roon Ready functionality. This means that their components will be able to function as a Roon Zone / streaming endpoint. Just as with Melco servers, the Roon Core (the library) will still have to run somewhere else.Sorry @Audire , I missed this question. No that won’t hurt. To clarify, the monitor is only useful to diagnose an actual hardware malfunction, it could then be used to identify the malfunctioning part allowing for just shipping a replacement part in stead of shipping the entire server back and forth. Although our failure rate is low, even after 5 years of the Extreme’s existence, failures can occur, and if your physical condition makes it difficult to handle a heavy piece of gear like the Extreme that’s most certainly a valid buying consideration. The N30SA is an excellent server and I understand you will be able to run Roon on it in the near future should the Conductor user interface be part of your consideration to switch servers.
Antipodes does not reclock the USB connection, which is why the I2S, AES, Toslink, etc. connections may sound better. That said, I think the USB out to my Premier via Pro USB sounds just fine.not to derail the thread, but i recently tried an antipodes oladra and found their connection over toslink with the word clock to be extremely enjoyable and in many songs better than their usb to the proisl connection. I'm not sure if this is from the server being designed to work better over toslnk/aes/is2 vs usb or not. Thus my question about which input is best suited for MSB with taiko. i also use the DD with my system fwiw
Thank you for the info. Does the taiko reclock their USB? what about aes, toslink etc also?Antipodes does not reclock the USB connection, which is why the I2S, AES, Toslink, etc. connections may sound better. That said, I think the USB out to my Premier via Pro USB sounds just fine.
Mechanics, thermodynamics and electromagnetism. What else in physics is needed to understand the Extreme? As far as I see you do not need quantum mechanics or relativity for your solid engineering developments.Pretty sure that was sarcasm![]()
Not interested in roon at all, as tried that twice now, and both times found it worse than qobuz when streaming the exact same track.
Roon has never sounded this good in my system. I also think Roon can sound better in some systems. I also like XDMS. Listening is like tasting wine, no ears or taste buds are alike...Its not against the rules to like them both...You might end up reconsidering that ;-)
The Taiko Extreme may well be the best option available for Roon.
Although the choices made by the Taiko Audio team fall a little outside the Roon Labs recommendations (separate server and endpoint) Roon's implementation in the Taiko Extreme is brilliant! Emile could talk about it (@Taiko Audio).
It allows you to enjoy Roon in an Ultra High End context, if I may say so.
Add to that the switch + network card + router package, and you've probably got one of the best transports available today.
Cheers,
Thomas
It's been a while since I compared dCS' Mosaic to the Extreme/Roon or Extreme/XDMS. Easy enough to do and I'll give it decent trial streaming from Qobuz this evening when I sit down to listen to music after dinner. I'll let you know what I hear.Been trying to find more reviews on owners with dCS kit. Been looking on the dCS forum, and others, getting very mixed results.
I guess the only way is to try for myself, but before I go asking dealer for a home demo, can I ask vivaldi apex dac owners what exactly did they find inpoved once they went over to the extreme over the built in streamer in the upsampler, when streaming qobuz.
Because like I said I don't want to waste dealers time, as right now it looks about a 50/50 split on if they decided it was better, no difference or even worse.
Cheers once again for helping
