Why? Just curious.$7000 for a $20 cable "treated"??? I don't think so......
I believe it is $2.5k promo from $4k.
Am I correct when I remembered Emile stated to use shortest useable DAC in one's system. Im not knocking QSA but I find the thought of paying for a 5 meter cable because it sounds better to be a stretch
This little grasshopper seems to be short sighted![]()
so if all you need is a one meter cable you have to buy a 5 meter cable because it works better??![]()
For me where I do take exception is having to buy 5 meters when all I need is a one meter length. Plus, let us not forget that if one does buy the QSA DC cable be prepared to buy another 5 meter length to connect your router to your switch. Here all I need is 0.5 meter length
here's a final follow up question. What if the user needs an 8 meter length and is told that 5 meters work best
Anyone thought of sending one of these to Emile for testing?
Perhaps not the right metaphor, but using QSA products with Taiko products seems like using Chinese herbal medicine with real antibiotics to treat an infection. Maybe the Chinese herbs have a benefit but I'd like the Taiko doctor to weight in before I would consider any of their products on the Extreme+switch+router+DCD. Taiko has gone to great lengths to voice their sound very carefully and I'm not sure I'm ready to use 3rd party anything until I get some sense from Taiko as to its merits. (Perhaps the 5m cable requirement is to leave room for a noose if their cable doesn't work out?)
Maybe it is only me but where I see the potential for DC cables is in the upcoming BPS but again I would defer to Emile's suggestion
I see qsa does speaker cables..
Has anyone heard these with their Taiko setup?
Hi
Thanks for the answers, I appreciate you taking the time to answer them.
I guess the next step is to try one in my system.
But I think going by the answers, I could sell my melco N10 to help fund this, and use the disc drive storage in the extreme? As it does have storage doesn't it, or can be added?
Cheers dunc
I have Taiko and also QSA ultimatum speaker cables. They work fine together and sound extremly goodI see qsa does speaker cables..
You don't represent QSA-Lanedri yet u know they are sending Emile cables?? Something fishy going on here...Yes, both the DAC cable and DC cables will be sent to Emile.
@Christiaan Punter already answered the question but here are Emile's own words:
"I don’t have a preference for which length to use."
I think I need to clarify network activity impact on sound quality. In a normal home setup with a X number of devices, smart TVs, streaming devices, desktop computers, notebooks, smartphones, tablets, smart lighting, smart household appliances, etc etc, adding more devices with a relatively...www.whatsbestforum.com
"7m is the maximum length.. Longer requires an active cable which unfortunately severely degrades SQ (to fiber levels)…"
I placed an order, and am trying to pay with Transferwise, but I've encountered this error I've never seen before: We cannot currently accept payments to this recipient. Does anyone else have this issue?www.whatsbestforum.com
So per Emile, as long as you don't go beyond 7m, you're fine.
Yes. I am not the manufacturer nor do I officially represent @QSA-LANEDRI but as I was involved in the R&D of some of their cables including this DAC cable, I will provide you some background on why certain decisions were made including this 5 meter length. Here's the bottom line: The greater the mass of conductor, the greater the impact of QSA's treatment.
Based on the above information provided by the manufacturer of this DAC cable, you can see that at lengths of 3m or less, small 30AWG conductor is used. It is at 5m length that the largest gauge (24AWG) conductor gets used. That is the basis for the 5m length. 6m and 7m length are available also. I believe that with the DAC cable, the price has nothing to do with length and the price is the same regardless of whether you get a treated 1m cable or 7m cable but as 24AWG is 4x more conductor mass than 30AWG, I would avoid anything less than 5m.
If you feel that strongly about getting a 1m length cable, that can be arranged but it won't cost you any less and it won't sound as good. We know that from experience. For those interested in giving it a try, I would suggest you get a 5m length cable, coil it with Velcro and and neatly tuck it away. Be aware that this cable is very much directional. If you connect it the wrong way, SQ will be worse.
As before, based on what Emile has stated, going beyond 7m, it becomes an active cable and there will be a SQ penalty. Consequently, QSA-Lanedri is not treating any cables beyond 7m. Any length between 5-7m should provide good results as these cables utilize the larger 24awg conductor with 7m probably sounding slightly better than 5m.
“... involved in the R&D of some of their cables including this DAC cable.” Seems normal that someone involved would know that.You don't represent QSA-Lanedri yet u know they are sending Emile cables?? Something fishy going on here...
I am in private conversations with Emile to send him cables. Nothing fishy going on. I am curious to know what he thinks and he is curious to know how they sound.
Don't tell him he is getting something with "Musical Metal molecule Alignment Technology (MMAT)"![]()
You're preaching to the choir. I'm afraid as I am not disputing anything you say and I understand the science you have laid out.. I have even said that everyone should have a listen in their system. But for me I truly don't buy into the fact that I have to purchase a minimum of 5 meters when all I need is much less which costs the same and sounds worse. yet in the same breath you state the 7 meter sounds best. As for my 8 meter comment you got my point I was trying to make but dwelled on the fact that 7 meter is the max. It's just not something that I personally find to my liking. As for the cable I did have a listen in my system and that's why I emphasize that everyone should if they are interested@Christiaan Punter already answered the question but here are Emile's own words:
