Are there issues with the USB Pro interface or are these just anectdotal snippets
The latter imho.
Hello pleroma,
Welcome to WBF. Which MSB dac do you own? Interesting approach to skip on the Pro USB for the Renderer because of the Ether Regen.
The Uptone LPS 1.2 can definitely power the EtherREGEN. Maybe your friend had it on the wrong voltage setting. It is recommended that the LPS 1.2 be set to 7V.
" ... Had a brief audition and some findings
1) LPS1-1.2 unable to power Etherregen ... its led turned red immediately after plugged into Etherregen. So, I power it with HDplex
2) I tried etherregen -> sotm switch.... didn’t notice advantage vs just sotm
Yes I know.That is incorrect! While an UltraCap LPS-1.2 can definitely power an EtherREGEN, it can do so only at 9V or 12V (12V recommended as this presents lowest load). At 7V the EtherREGEN will draw about 1.35A--just able the LPS-1.2's 1.1A limit.
There was some hiccups during the connection with an optical cable and the sound was stuttering such that we have to change back to a conventional LAN cable. Stuttering persisted for a while then they played normally.
There is a good chance that his power supply connections--with the HDPlex are defeating the isolation of the EtherREGEN. He should power it with either the stock SMPS we include or the UltraCap LPS-1.2 set to 12V.
So the etheregen and sotm switch is doing different things. I take it the report for chaining 3-4 of this device is incoming. Very promising.Here is another friend of mine who went to pick up his ER. We group-ordered ER and all of them were mailed to another frd's place.
" ... Had only very brief listening for me. When I arrived at 10pm, LS was listening ER on its own playing a Beethoven cello sonata. The sound was quite raw and the piano seemed dominant with good presence and energy while the cello a bit lean and anemic. More like a piano solo if I exaggerate a bit.
We then changed back to Sotm alone. Now the sound is more smooth and the cello more beautiful sounding but the piano lost body and speed.
We then tried SotM + ER together. There was some hiccups during the connection with an optical cable and the sound was stuttering such that we have to change back to a conventional LAN cable. Stuttering persisted for a while then they played normally.
Now both the cello and piano has full body and sang beautifully and the background is much more quiet that the ambience was naturally reproduced.
That was only 10 minutes after they played normally and the sound seemed getting even better when I left at 10:50.
With Sotm or ER alone it seemed that we were listening to two different recordings and with both we were listening live ..."
The cello sonata he mentioned was Beethoven played by Fournier & Gulda on DG.
The combo they listened to consisted of a diy server running HQPlayer. The dac was a Denafrips Terminator.
Again, they both own a SOtM switch already and buying ER is for installing a dual-switch config.
Please note that I am merely a reporter for these two posts.
I haven't picked up my ER yet.
Since we are at it, why not both ways. Thank you so much CK. Really appreciate the effort sir.I think that’s an interesting question....also in which order SoTM —-ER or the reverse. . Sometimes its quite fun, being anal.
I asked.Since we are at it, why not both ways. Thank you so much CK. Really appreciate the effort sir.
The comments on #65 :CK, Thank you for your sharing of the ER and sotm and looking forward for you and your friends in testing the "Ultimate switch setup" using Cybershaft and Mutec OP20 clock both Sotm and ER switches!
CK, I would also be very interested to know if an external clock improves EtherRegen (especially with the Mutec clock). Alex Crespi thinks not, since his XO is of very high quality and is millimeters away from the chip, but he certainly states that until tests are done, it cannot be affirmed in one way or another.
Or massively over complex, depending on your point of view and the sound quality levels achieved. . With that level of complexity i would expect a room chock full of highly realistic 3 dimensional music that sounds like it originates directly from the instruments, with all the clues that musicians and their instruments are present and no anomalies what-so-ever and I would expect to be fully transported to the size, shape, type, atmosphere and ambience of the recording venue. Its not worth complicating matters to this degree unless the results are utterly stellar....moving you to tears if you’re the emotional sort and sounding quite frankly the best you’ve ever heard, ever...speakers and room included. If your system doesn’t sound like that or as a minimum very closely approaching that, you’re overcomplicating some parts of your set-up compared to other parts, very typically speaker placement and room tend to fall behind. This is not a criticism....for all I know, your friend’s system IS stellar and fully deserving the extra detail and complexity. Just saying what my expectations would be when those measures are in balance and harmony with the rest of the system.Hols@Audiophilestyle just gave a complete report of his experience for Etheregen. He using ER - SOTM double stack clocked to Cybershaft OP20 and another ER between his router and NAS. It sounds promising.
