Sorry if I missed this. Have any of you used Triton X114 as a surfactant. Do you find it washes away or remains. I make a mix with 99% alcohol, distilled water and Triton x114.
Should have also asked. Is the P60 the same power of cleaning as the P120 when you consider tank size.
What is the rack tima and others use. I don't see a link or brand. Is it home made.
He's using this one. It's nice but doesn't protect labels in the same way.
Hi Kingrex - Triton X114 is likely the non-ionic surfactant most likely found in Kodak Photo-Flo. In an ultrasonic tank (UST) it should be used room temperature. It is judged an environmental aquatic toxin and being phased out. *
@Folsom - Tergitol X100 is a nonylphenol ethoxlate (NPE) chemical compound. NPE is shown to have aquatic toxicity and possible material compatibility risks and it is being phased out.**
If you want to use Tergitol, the recommendation is for Tergitol 15-S-9. Similar to Tergitol 15-S-9 is Ilford Ilfotol, which I use. Ilfotol was originally used in photograph development as rinse agent.***
For solution I've been using ~12.75L of distilled water, 312ml of 99.9% pure IPA and 16ml of Ilford Ilfotol. As you know, IPA vapors are flammable at concentrations of 2% and higher. At 2% concentration the IPA flashpoint is 65°C; at 20% concentration the IPA flashpoint is 30°C. The concentration I use is 2.4% with heated tank temperature topping out at ~32°C to ~35°C so I've been taking a slight risk but have had no problems. Going forward I plan to reduce the IPA concentration to ~2.0%. ****
During ultrasonic cleaning, the Tergitol and Ilfotol products will leave residue in the grooves. To remove it requires a pure water rinse.
References: Precision Aqueous Cleaning of: Vinyl Records (PDF) by Neil Antin, published at The Vinyl Press
* - section VIII.7
** - section IX.4.c
*** - section VIII.6
**** - section VIII.8.c
Interesting. I'm glad I don't use Tergitol.
Hi Kingrex - Triton X114 is likely the non-ionic surfactant most likely found in Kodak Photo-Flo. In an ultrasonic tank (UST) it should be used at room temperature. It is judged an environmental aquatic toxin and being phased out. *
@Folsom - Triton X100 is a nonylphenol ethoxlate (NPE) chemical compound. NPE is shown to have aquatic toxicity and possible material compatibility risks and it is being phased out.**
If you want to use Tergitol, the recommendation is for Tergitol 15-S-9. Similar to Tergitol 15-S-9 is Ilford Ilfotol, which I use. Ilfotol was originally used in photograph development as a rinse agent.***
* - section VIII.7
** - section IX.4.c
Running distilled water over it wont get deep Lfotol residues, will it???
I saw the 62 post. What I did not see was an effective power when you take into accound the ultrasonic waves have to penetrate a lot more water. Wondered if the smaller 60 machine was working as well on 3 records as the 120 on 6.
All the photo stuff have lubricants in them, which doesn't sound appealing, but maybe it makes records sound like they have LAST on them or something?
??? do you have a reference?
With regard to cost Ilfotol is about half the cost of the Tergitol 15-S-9 on the Web site you posted.
It's been talked about a lot. There's many forums discussing it. For example. Overall though if you don't have any build up on your stylus it's probably more nit-picky than anything.
When you look in the water afterwards you see stuff in it, that stuff can resettle on the LP, so a rinse of some kind is mandatory IMO.
That isn’t the case if you are constantly filter the water during the cleaning process. I can’t say that I ever see particles in the water, ever. The TDS meter readings after I have cleaned 50 records may still only be 6 Ppm.
Depends how long it takes for you to completely filter the water multiple times over. A vacuum and having a filter is best.
If you don't want to have to change water frequently then using a filter system is great. But the water needs something in it to inhibit growth. So if you put in IPA that works. However the problem then is that IPA causes static. So when you do a rinse and vacuum you can use pure water and in my case I use a touch of hepistat, and this leaves you with zero static, instead of tiny amounts.
I can only speak for what I do. I never have any issues with static, even in the dead of winter when my house is pretty dry. That wasn’t the case when I used a KLAudio or AudioDesk. I like the fact that once I am done cleaning I am not touching the surface of the record with anything else prior to playing it.
