I am curious of the reasons why some people who can easily accept a usd 25000 preamplifier or a usd 150000 amplifier find objectionable an usd 20000 cable. Question of size or weight?
Comparison with other industries is not meaningful, unless they have similar structures and purposes. What should we compare with the the high-end industry?
- Because I've never heard the value before. Everytime I've swapped in a super expensive cable vs. the good quality, simple copper stuff I primarily use, it's never better, maybe sometimes different though.
- I'm not an engineer, so take this as you will, but I've never read anything that's convinced me that some of the elaborate construction or exotic materials of some of the really expensive stuff adds anything over a good copper design. My BS detector goes off. And from an advertising/marketing staindpoint, something which is my business, the detector really screams.
- I open a good preamp for ex., let's take my ARC Ref 5. I see a ton of parts including wire, and a lot of design work. Then I see a piece of wire for the same $$$ -- there goes my BS detector again. And why/how is that speaker wire, at the end of a chain with a ton of wire already, transformative? If so, it points to a problem.
- Swapping out, say, the Ref 5 for a $2K preamp, I immediately here a difference and improvement. Usually easily discerned. Not my experience with cables. Further, I think a couple hundred bucks of room treatment, for ex. will always get you greater improvement than a couple thousand or more spent on cables. Bad value again.
- With so many variables/components in the equation, I really want cables that do nothing. My speaker choice, for ex., is my primary choice for how my system will sound (and it is the only one that interacts w/the room too) I don't want voicing from a cable, and I think that may be what alot of the expensive stuff does. I want this passive component to remain passive. And I don't see how the more expensive stuff gets closer to doing nothing.
I elaborate a bit on all this in this review:
http://www.sonicflare.com/archives/supra-sword-speaker-cable-and-plydual-wire-review.php
Listen, other people's opinions on cable are fine with me. Last thing I want to do is start this old argument. I consider myself pragmatic, not dogmatic; after years in this hobby, years of listening, this is where I've arrived. I just don't see value in cables -- first and last from a sonic standpoint, and from others in between.
To paraphrase Mark Twain, if I'd had more time, I would have made this post shorter.
