My opinion on the video only is that it sounded a bit jumbled up, probably due to reflections, and I preferred the older way.
With other system on forum you only read and don't hear how it progresses. If the sound sucks no one let you hear it or read about it. With my system, you hear it as we go along. It takes Mike how many years to get his room where it is now. Nothing happens by chances. It sure wont take me two week to get where I want. I am just happy knowing my system can leap forward after taking the acoustic panels out. Next step is to work on a more proper room acoustic.
Btw Tang you are not at two weeks, just saying.
Hi Tang,
FWIW - imho the latest vid sounds too reflective and the bass cluttered / muddier than previous vids. Maybe it sounds better in person, but i think you’ll need something to clean up the bass and perhaps some more diffusion to assist with those reflections (if you are averse to absorption.
Maybe more absorption behind the desk? The issue with bass is it travels and reflects everywhere because it has very long wave lengths. If you get nodes and modes from having less absorption, well, you get the idea. The thing is I'm not sure Tang hears any of what you hear, because phones are BAD at bass recording. It might just be overall better for him - and he doesn't have a lot of bass anyways without the subs those speakers usually come with.
I meant get things done in two weeks. I am absorbing what I am hearing from playing different records for the time being. And also having two guys free themself from normal work to lift things in and out for me. The kind of shit you would do when you really want to pin down something dear Ked.Btw Tang you are not at two weeks, just saying.
Thank you awsmone. For the lovely Bruckner too.hi Tang
yes I understand your explorations done all this myself over 6 years !
i think a live room has a lot of advantages, but glass is always a challenge
but you may need to moderate the bass , the bass boost may have affected the timbral balance, but also decreased the clarity of the bass
pulling the bass out from the wall to get the clarity, versus fullness is where the art comes in
i don’t know how easy this is to adjust for you, but I would pull out till it becomes fast and a bit lean, and mark this point on the ground with some tape
i would then move back till you achieve the timbral balance you want , you need increments of 1cm and best to place a tape measure going from the lean point you have identified with marking tape
this point can be guessed at, if you walk and talk from the front wall till your voice looses the bass boost from the wall
once you have that correct , you can play with if covering areas of the glass, to diffuse the front wall, without too much attenuation, some semitransparent curtains may be all you need,
Listened to this marvellous recording Sunday
Dynamic range and timbral colours to test any system lovely tempi in first mvmt
listen for 7:45 for brass colours and timbres
wonderful brass chorale from 8:30
and gentle second theme from 9:15 I love the build to that chorale of brass sublime !
if your into harmony listen for the chord at 9:04 so modern
2 4 and 7 and all wonderfulThe 4th is a beauty for sure and Sir Colin is an unsung genius.
However his 2nd,especially the finale is truly magnificent.
Kindest regards,G.
