I must admit, I could never buy a cart sound unheard. In fact, only gear that comes with a guaranteed sale or return policy will get considered if dealer demo can't otherwise be secured. I'm sure that applies to most of us.
I doubt a visit to Cristian would be a disappointment, and he has AS2000.His first step should be to visit Milan, Heathrow, and Germany to hear horns. If he goes to the the US he will probably end up visiting Wilson owners along the way and not learning much else
Let me see how this is gonna go again. Home trial on an amp isn't informed in yr opinion? Well it informs me as to whether I like it or not. So it's informative.What does return policy mean? You get an amp home, if it sounds better than your current amp you do not return it, else you do. That's informed?
Duh!!!
Oh, I forgot. I should really be running half way around the world to inform myself if it sounds good or bad in other guys' systems. Well, that's all fine and dandy. But I dont run their systems in their rooms. I run mine in mine. So, home trial, thank you very much.
Of course, if my audio life was the gaining of data points, then this system wouldn't work. But it's not.
In my most humble opinion.
Whatever happened to "I like it, I'll have it, thanks"? We all got it wrong prior to you enlightening us, Ked.
No disrespect Tang, its only Ked online who's informing people they're not informed when making choices.
I guess by his definition, virtually everyone is ill informed. I suspect he feels he has to inform us of our terrible choices and decision making. Too bad this comes over as arrogant rather than inclusive.
Tang, did you also demo Mayer in yr system, versus any number of other amps, both tubes and SS? Did you then go and check yr preferences were objectively arrived at, by travelling to hear multiple alternative systems where these amps were installed? Any number of times?
Or did you do what normal typical audiophiles do? You have a relationship w David, and he provided you w Lamms, you tried them out, and you preferred them to yr Ayons. And bought them.
Has Ked told you that you were ill informed? Or is it only others that get this verdict?
Now calling Tang a typical audiophile is somewhat of a stretchTang, did you also demo Mayer in yr system, versus any number of other amps, both tubes and SS? Did you then go and check yr preferences were objectively arrived at, by travelling to hear multiple alternative systems where these amps were installed? Any number of times?
I'm the bright sun that enables you to cast yr shadow of blanket criticisms.Well yes, I actually told him to roll amps when I was at his place. Wow Marc, you are brighter than I gave you credit for
Ked, I can't think of many other than Tang or Mike who could entertain running multiple tts, arms, carts, and come to l/t decisions. If this is the correct measure on how to choose, I'm out.
PS we agree blind buying can't make much sense.
No disrespect Ked, Bill has chosen gear. Kuzma to SME to Vyger is evidence.
Now, if you'd argue to stick w your first serious system, in my case that could have been a £1k Rega rig from 1995, and spend the money spent on gear instead on vinyl, one would indeed have a very nice collectible/superior 5-10k strong lp investment.
Ked, I haven't got an economics degree, so can't argue w you there.
Just what has Mike done to make him informed? I don't ever recall him saying he was going to try X number of tts prior to settling on NVS. He had the Sirius for a decade, a Beat and a 301. Before settling on NVS, I don't believe he trialled big hitters like SME30, Brinkmann, GP Monaco, Saskia, Continuum. He had a relationship w NVS dealer, trialled it and ran with it.
How is this any different to anyone having a l/t reference, one or two experiments concurrently, and one's dealer selling you his flagship.
Did Mike run thru extensive numbers of amps? No, Levinson to Tenor to Dartzeel. Again, no massive series of ABs.
Ditto spkrs, moving thru Kharma to VS to EA.
Just where is Mike ticking yr boxes and the majority aren't?
