Reality is Cruel : Cybershaft new Ultimate OCXO 10M Clocks Shootout OP20 vs OP17
JaMo
9
8
5
Sweden
Just to let You know. This thread made me curious about these high grade OCXO's.. So I ended up ordering a REF10 SE-120. Will hopefully get it in middle of mars. Thanks/Jan
Reactions: vhs and TLi
JaMo
9
8
5
Sweden
The Mutec REF10 SE-120 has arrived! It is put to do service and a two weeks burn in period has started.
JaMo
9
8
5
Sweden
congratulations ! Feed it with premium clock cable and place it with SS Ultra. You surely will get all the best out of it.
Thanks! And thanks also for the recommendations. Cables are already taken care of, SS Ultra is still on shopping list.
/Jan
Sa683s
37
28
123
/Jan
Or you can try SS Ultra 2, a crazy guy here used and hv even better results than Ultra.
Reactions: vhs
vhs
38
42
105
Wow!
Ultra 2 is indeed much better than Ultra.
Stbo
34
43
105
61
Sweden
Don't forget a high-quality power cable and for the last bit of perfomance high-quality fuses too.
I had my Ref10 upgraded to the -120 status in January and I' m really enyoing it now.
Btw. Just for curiosity JaMo, which clock cable do you have?
Reactions: johndoe21ro
JaMo
9
8
5
Sweden
Power cable is now a rather simple interim solution during the burn in peroiod. I am waiting for 6.4 AWG cable.
75 Ohm BNC cable is Mutec's own 0.5m. 50 Ohm I use Mil spec (RG223 from 1966) 1.0m. Will upgrade those to shorter ones later
David
83
10
913
Hi everyone, I am one of the lucky owners of this spectacular Mutec Ref10 SE-120.
The Mutec absolutely takes the already exceptional dCS Vivaldi Clock to a whole new level ! View attachment 59770
Dear VHS,
i have seen that you, use an Uptone EtherREGEN switch into your system ... did you tried also the Mutec Ref10 or Ref10 SE120 with your EtherREGEN switch ? If yes, could you let me know if it was positive ?
vhs
38
42
105
Dear VHS,
Hi David,
I did make a direct comparison between Ref10 and Ref10 SE-120 with eR which both substantially improved the sound quality.
The decision is a no-brainer. Please go for a SE-120 however.
vhs
Reactions: Marck1973
Marck1973
34
23
113
Hi,
So I managed to demo a Ref-10 with my full Vivaldi stack, and as stated above, it is a no brainer. The difference with using the external clock was not subtle, a significant improvement.
I decided to wait for the Ref-10 SE120 version which I received nearly 2 weeks ago now. I was told to expect a further 10% improvement over the standard Ref-10.However I would say the improvement between the two is more than that, maybe closer to 20%. if you have the opportunity, as VHS mentioned, it is the SE120 version you need to go for.
Another point is to make sure you use the best power cable and clock cable (keep all clock cables the same within the loom).
Having the external clock has taken my system to an entirely new level, it really is a no brainer!
Marc.
vhs
38
42
105
Hi,
Marc.
Hi Marc,
You must try Stillpoints Ultra 2......it is a perfect match for Mutec Ref10 SE-120.
Cheers,
vhs
Marck1973
34
23
113
Hi Marc,
Cheers,
vhs
So I used to use StillPoints in my system however recently took them out since I have a new Artesania rack which made a massive difference. The clock is actually sitting on a VertexAQ platform on the rack since the new rack doesn't have shelves and the unit is too small to reach the carbon struts.
I may try the StillPoints though since have kept a few back incase ever needed!
I will try and upload a photo of the system so you can see what i mean!
Reactions: vhs
vhs
38
42
105
TLi
442
1,124
253
I just completed my order with Cybershaft for an OP21A to go with my Vivaldi stack.Looking forward to this.
Big congratulation. You make the right choice. Remember to get the external power supply and the spike footers from Cybershaft as well. They are not expensive but very effective.
Their 50Ohm clock cable is not bad too.
drunkenspyder
31
27
85
NorCal, USA
www.hammondraffetto.art
Yes, I included the external power supply and spike footers for both boxes. Kenji does not offer 75 Ohm cables, but does offer good 50 Ohm cables with adapters. I prefer to stick with 75 Ohm. And I have some good basic clock cables built by Geistnote already . These will hold me over until shelter-in-place gets lifted, and I can travel to my dealer to audition the Shunyata and others. I'm not buying those without listening.
