Just to let You know. This thread made me curious about these high grade OCXO's.. So I ended up ordering a REF10 SE-120. Will hopefully get it in middle of mars. Thanks/Jan
congratulations ! Feed it with premium clock cable and place it with SS Ultra. You surely will get all the best out of it.The Mutec REF10 SE-120 has arrived! It is put to do service and a two weeks burn in period has started.
Or you can try SS Ultra 2, a crazy guy here used and hv even better results than Ultra.Thanks! And thanks also for the recommendations. Cables are already taken care of, SS Ultra is still on shopping list.
/Jan
Thanks for the reply. I have an OP13 Ultimate with a Mutec 3+ USB which I am very happy with. Maybe someday I will consider upgrading.
Don't forget a high-quality power cable and for the last bit of perfomance high-quality fuses too.congratulations ! Feed it with premium clock cable and place it with SS Ultra. You surely will get all the best out of it.
I had my Ref10 upgraded to the -120 status in January and I' m really enyoing it now.
Btw. Just for curiosity JaMo, which clock cable do you have?
Hi everyone, I am one of the lucky owners of this spectacular Mutec Ref10 SE-120.
The Mutec absolutely takes the already exceptional dCS Vivaldi Clock to a whole new level !View attachment 59770
Dear VHS,
i have seen that you, use an Uptone EtherREGEN switch into your system ... did you tried also the Mutec Ref10 or Ref10 SE120 with your EtherREGEN switch ? If yes, could you let me know if it was positive ?
Hi,
So I managed to demo a Ref-10 with my full Vivaldi stack, and as stated above, it is a no brainer. The difference with using the external clock was not subtle, a significant improvement.
I decided to wait for the Ref-10 SE120 version which I received nearly 2 weeks ago now. I was told to expect a further 10% improvement over the standard Ref-10.However I would say the improvement between the two is more than that, maybe closer to 20%. if you have the opportunity, as VHS mentioned, it is the SE120 version you need to go for.
Another point is to make sure you use the best power cable and clock cable (keep all clock cables the same within the loom).
Having the external clock has taken my system to an entirely new level, it really is a no brainer!
Marc.
So I used to use StillPoints in my system however recently took them out since I have a new Artesania rack which made a massive difference. The clock is actually sitting on a VertexAQ platform on the rack since the new rack doesn't have shelves and the unit is too small to reach the carbon struts.Hi Marc,
You must try Stillpoints Ultra 2......it is a perfect match for Mutec Ref10 SE-120.
Cheers,
vhs
Big congratulation. You make the right choice. Remember to get the external power supply and the spike footers from Cybershaft as well. They are not expensive but very effective.I just completed my order with Cybershaft for an OP21A to go with my Vivaldi stack.Looking forward to this.
