had anyone looked at Synergistic Research Tranquilty Base as an option?
According to this pricelist, the XL (20" x 23.25") retails for only $ 2,995.
First, thank you to Christian for having started a great thread of importance. And thanks to Mike too for his invaluable contributions.
...And to everyone else who are participating and contributing by confirming the results observed by Christian and Mike, from this fascinating and scientific subject that goes beyond the musical exploration of turntable's vibrations elimination with extreme prejudice to the highest degree. ...As it started for very precise microscope instrumentation in the field of chemistry and medicine.
And thank you Reid for your writings, your links, and those pictures I asked for.
That is What's Best should always be about, among other great things of top interest.
When people like Christian and Mike are talking, I am listening. And when Reid joined in, I was already hooked.
I am a total believer, and money is now not so relevant anymore in a world of perfectionism in the goal of improving our lives and our musical involvement to serve our enjoyment.
* Michael Fremer should be here too with us.
I wouldn't be surprised too to see them under high-end CD/SACD players.
I fully believe in isolating and eliminating all type of internal and external vibrations when it comes to "our sound".
...Be it analog, or digital. ...And like in this case here; turntables are the perfect alibi.
Then the first big kudos goes to Mike!
But that was still your enterprise to start this thread Christian.
I checked the link, it doesn't have a specific list of its composition with technical description. Is there more to it to learn more concretely?
What I see is a nice looking platform, with a cool name, and few words here, and few more there from people having experienced it.
I also looked for reviews but found none. Perhaps I didn't search hard enough?
Here is a couple iphone pics of the setup tonight...
For those on the fence, look at it this way, it costs you only shipping to try out the unit. If it doesn't work for your particular table/stand combo, you return it for a full refund minus shipping....roughly $90.00.
I've got the possibility of a demo of a Halcyonics i4. Until recently, isolation never made as much a difference in my setup as power. However with my Symposium Isis rack, things have definitely taken a step fwd. The problem on this demo is that it's going to be counterproductive placing an i4 on an already floating Isis shelf, and any wall shelf will only get installed IF i go for the i4. I have my old fixed rack moved over to house my av components. For the purpose of the i4 demo, should I move it back next to my Isis, resite the tt as before, and then proceed with the demo? I guess if the old rack + i4 + tt outperforms the Isis + tt, I can be assured that this will extend to use of wall shelf. So the decision to go ahead will be based on whether this difference is really significant to justify c$9k. It will have to, since the Isis is SO good at vibration control - with my old rack, moderate footfall caused my air bearing linear tracking arm to skip, with the Isis in place, I can literally jump up and down in front of the tt (what my girlfriend calls my dancing!), and the arm doesn't skip a beat. The only difficult issue here is that my tt/arm/cart has taken such a long time to dial in, that i fear change of environment will introduce a negative set up variable that may negatively bias the outcome of this a-b.
Could I not just plonk the i4 on my current Isis, and even though this wouldn't be perfect in the long run, still get a flavour of performance improvements?
I have a HRS MXR stand. Any idea what kind of results I would get if a Herzan was placed on it? I assume this would not be ideal?
Peter, just spoken to the European distributor for Accurion. The i4/Micro 40/Silencer will NOT work in conjunction with a passive isolation device, only on a fixed, stable platform spiked to the floor. So on my Isis is out. Mike's Adona rack would be perfect. Luckily in the UK there is Northwest Analogue who make reasonably priced slate based racks with spikes that should provide the required inertness for the i4 to sit on. Personally if this works for my tt, I'll seriously consider ONE extra unit for my Emm labs CDSA. The amps/psu's/balanced transformer/earthing box, can remain on my isis rack that's already doing a remarkable job. Sources must surely take precedence. At c$9k a shelf, that's about as much as I could afford.
Man, it's a good thing you're the height of an NBA power forward. I could probably check SRA on your rig standing straight.![]()
