I am going to order one (the 1800W model) for my computer and smaller ones for the internet router and repeaters. And oops, i will have to change the outlet
If I were you I would change the wall outlet to a Hubbell. Much less insertion losses. Better contact. Solid brass. No tin plating. You could use the 20 amp version. But if your going to change, just get the higher ampacity, better current flow item. They will both fit in a single gang box. 20 or 30 amp.
Locking Devices, Twist-Lock®, Industrial, Flush Receptacle, 30A 125V, 2-Pole 3-Wire Grounding, L5-30R, Screw Terminal, Black | HBL2610 | Hubbell Wiring Device-Kellems
Locking Devices, Twist-Lock®, Industrial, Flush Receptacle, 30A 125V, 2-Pole 3-Wire Grounding, L5-30R, Screw Terminal, Black.
30 amp Twist-Lock Male Plug | Locking Devices | HBL2611 | Hubbell Wiring Device-Kellems
The 30 Amp Twist-Lock Male Plug ensures secure connections with its Twist-Lock® mechanism, rated at 30A 125V, featuring 2-pole 3-wire grounding, L5-30P, and screw terminal.
