Christiaan Punter
Hi Surge1, It's good to know you are not that bothered by it but such things really bug me and I can't help wanting the know the culprit. Roon should be quite stable and not be losing the connection to the DAC this frequently.Hi Christiaan,
Thanks. Yes, today Roon wasn’t playing so I had to reboot the Extreme. When I press play, it saying “playing” for a second, but nothing happens, and I don’t hear the Nagra DAC’s relay clicking. Roon then seems to give up.
I’m not really worried about it, as I’ll never run Roon again once XDMS is out…
If you don't want to further pursue this just let me know. Otherwise, let's try and troubleshoot this
I assume you have probably already ruled out the obvious, that the USB cable might be faulty or off-spec? In my experience, in their quest for better sound, some high-end cables are less widely compatible. They may work just fine on one server-DAC combination but intermittently or not at all in another combination. In case of doubt, just grab any standard good quality 1-meter USB cable for a test. This won't sound as good but it should make a stable connection.
A less probable cause might be a faulty network cable (maybe the pins are not crimped on perfectly or there could be a knick in one of the wires that can cause intermittent issues. Granted, in this case, all Roon control would probably cease and you'd not see the behavior that you described. I'd wager that the same goes for the network switch and router. Still, I'd recommend swapping every component out one by one, just to be sure.
Finally, do you have another USB DAC at hand or can you borrow one, just to rule out that final stage? I'm sure the DAC itself is not the culprit but it would help the troubleshooting process if we knew that the issue is also present with another DAC, preferably one with another USB receiver chip.
Sorry, just grasping at straws here...
