Does the Taiko router also work as a modem???It could accept the service provider fiber directly. Subsequently you could create a separated audio and rest-of-home network.
Obviously it could also be placed behind the fiber modem.
Depending on your definition of modem, yes, and of course your service provider needs to support using your own.
Are you going to do some testing with the major ISPs in each region to see which work with your router at a replacement or is that our own responsibility?
I don’t think that’s realistically executable. We will have to see how to approach that.
It’s not an uncommon practice, see here for example https://www.gadgetreview.com/how-to-replace-isp-router-with-your-own (first hit on googling “how to replace your internet router”)
I was actually thinking you could recruit people from multiple locations to do testing and report back.
In the US with Verizon, you MUST use their ONT box and then their router to connect the incoming fiber. If you don't do this your tv channels will not work properly. You can get internet if that's all you use, but most people have TV coming in as well. I have investigated this issue in depth with Verizon in the past. No way around it.I was actually thinking you could recruit people from multiple locations to do testing and report back.
...oh, but don't you miss that beautiful sound? And connecting to Telnet for audio Usegroups.transmitting data over an analogue phone line which is not what we’re using anymore nowadays.
Haven't tried the Brimar (heard great things about them), but the Sylvania VT-231s are fantastic in my AtmaSphere amps.1943 Sylvania VT-231GT and Brimar CV1988
Not exactly.In the US with Verizon, you MUST use their ONT box and then their router to connect the incoming fiber. If you don't do this your tv channels will not work properly. You can get internet if that's all you use, but most people have TV coming in as well. I have investigated this issue in depth with Verizon in the past. No way around it.
I have currently changed my fiber modem to a higher grade one with a lpsu, sq uplift was very big, on par with a switch upgrade. However, it entailed changing the mac address of the new modem to the same as the operator supplied one. Is it possible to do that with the Taiko router?
Hi Steve, do you mean this one?It's an Obi satellite with a LPS . The satellite has 3 ethernet ports. I take an ethernet cable out from the satellite to the Extreme and I have never had an issue. I do believe Emile however that his pending updates will take the network to a whole new level so I'm all in thanks to Emile
Well, since my ISP's Router also works for TV services, I guess I'll have to place the Taiko Router after my ISP's Router. In this case, would we make a LAN to LAN connection with the Taiko Router's DHCP services disabled or a LAN to WAN connection creating a second network for audio only?Depending on your definition of modem, yes, and of course your service provider needs to support using your own.
Thanks! I actually needed to read up on this...perhaps this may be of interest reAC cables:
What's DAC Cable And Why Choose It Over Fiber Transceiver?
This article make an introduction of the DAC cable, its types, why choose it over optical transceivers and where to use itwww.fiber-optic-solutions.com
