Most of us bought the card and switch together since with the switch the card significantly outshines the mobo lan port.
To be clear, I'm using the switch and the network card. This is about adding a second network card to connect to a DAC that requires Ethernet input. The processing benefits of the switch network card pairing don't apply to using the network card to connect to a DAC. As a result the differences between the port and the network card are much smaller for output rather than input.Most of us bought the card and switch together since with the switch the card significantly outshines the mobo lan port.
While we are touching on this subject briefly, the preferred ethernet cable is CAT6?Somewhat different context but many months ago in this thread I compared the original opticalModule to a Startech FMC to an unclocked EtherRegen and found the opticalModule was an audible improvement. No reason to believe the opticalModule Deluxe would be a step backwards.
However, even before the introduction of the Taiko switch and new network interface card to my system I went back to using UTP copper ethernet without any fiber conversions from my home LAN router direct to the Extreme and found it to be a significant step up in sound quality.
Steve Z
CAT6A is the same, correct?
The real question I have is about the connector. I have a Metz connector. When you take it apart, it has a circuit board in it. Is it better to have an ethernet cable connector which crimps directly onto the wire?
Which ethernet cable are you using? Because, I need to have a long cable made, to run from my router to my system.
I can make up my own ethernet cables. If we are back to simple, ethernet cables, is it comparable to make your own cable?
thank you
CAT 6A is spec'd and constructed -- both wire and connections -- to tighter tolerances than CAT 6. CAT 6A will allow 10 Gbps to 100 meters, while CAT6 is about half this. Both are more than enough for digital music transmission at 1 Gbps speeds as used with the Extreme/Taiko switch and (soon) Taiko router.While we are touching on this subject briefly, the preferred ethernet cable is CAT6?
thank you
You’re committed Steve! Keep us posted…This got me thinking though, so I looked up the literature on Metz RJ-45 ethernet connectors to see if the shield connection could be defeated. It is a little difficult to tell from the picture but it appears that the shield spring connection at the back of the shell (right side picture) could be removed and/or the connection could be insulated with a little tape. The brochure says no special tools are necessary so maybe later today I'll take one of my jumpers apart and see if I can break the shield connection from one end to the other.
Steve Z
Might be most interesting to see what the addition of another switch between the extreme and your dac would doTo be clear, I'm using the switch and the network card. This is about adding a second network card to connect to a DAC that requires Ethernet input. The processing benefits of the switch network card pairing don't apply to using the network card to connect to a DAC. As a result the differences between the port and the network card are much smaller for output rather than input.
I’ve lent my SOtM switches to friends, so can’t try that now. However, I did previously try putting the two switches in between the router and the Taiko switch and thought there was a loss of clarity.Might be most interesting to see what the addition of another switch between the extreme and your dac would do
Well, first part of the project is done. Though the fancy metal connectors on my ethernet cable turned out to be Panduit rather than Metz (and didn't just snap apart and back together) I was able to slip a small, stiff piece of plastic under the strain-relief at the back of the shell between the bundle of shield and drain wire and the metal shell. Checked with an ohmmeter and no conductivity end to end now.You’re committed Steve! Keep us posted…
Hi Joet, thanks for the extra confirmation. Don't worry, even if your initial post may have caused something of a stir, the information is still valuable and I'm sure will be of help to other customers with a streaming DAC.Hi, as promised I've waited a few days and burned in the new card before reporting back. I've run a system disc for 4 days straight and things seem to have normalized.
First of all, I want to apologize for creating churn while reporting on the way things sounded while it was clearly breaking in. I thought people might benefit from the data points. Once again, apologies.
Here's what I've found:
1)There is no longer a perceived difference in volume between the cards and the issues with sibilance have subsided.
2) To me, the differences are subtle, perhaps very subtle, between the network card and the LAN port.
3) The network card seems more controlled and balanced. For example, in Norah Jones' "Come Away With Me" there is restraint when she hits a high note. You don't get the distortion in that upper register that I've heard in every system I've had before this, including with the LAN port. To be clear, it's not as if the note is clipped, it's more as if the system has control of it and is gently guiding it. Overall, you hear the resolution, but it's not calling attention to itself as a unit that is biased toward the top-end might.
4) Some might consider the LAN port to have slightly more sparkle. What it gives up in control it makes up for in liveliness. It calls attention to the high-frequency detail, which often brings a sense of excitement. However, what it gains in excitement might be offset by fatigue.
All this said the difference is small, perhaps very small. For those connecting via Ethernet who have a choice of using the network card to connect to their DAC, it's a matter of taste. If I'd done this experiment before purchasing the card I might not have thought it was worth the effort and $2K. However, now that I have it installed and paid for, my tastes run along the lines of the network card. I will likely keep it because I find it more controlled and less fatiguing. However, I can see others preferring the LAN port and there's a large part of me that believes I'm being too extravagant by making a large purchase for such a small gain.
The latest update for the Routers was on 25-05-2023 when Emile estimated that the new PCBs with WIFI would take around 4 weeks but that It’s probably more up to when the Router cases surface finishing is applied. Meanwhile, all I can add is that wifi implementation is ongoing and that no predetermined due ready date has been set just yet.Is there any updated ship date for the routers/ power distributors?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
