Now peace has returned to this thread, some quick practical considerations for Tang:
1) Placing the Daizas on carpet is not what they are designed for. It just does not work well.
2) Rubber, compliant, or ball bearing footers defeat most of the Daizas purpose.
3) I do not consider the Daiza to be a replacement for the CMS stand, although it could practically serve that purpose. Sure you can attempt to go there, and you may even end up preferring it that way, but the floor would need to be solid, or its just not an option. The CMS is a stand, the Daiza is a tweak. There is a ~10 fold price differential between them for good reason.
4) My suggestion is to place the Lamms back on the CMS stands.
5) Then try with the Daizas between Lamms and stands but use different solid footers, I am sending you a bunch on Monday.
6) From the video analysis it looks to me like there are some resonance issues with the Lamms on the CMS stands as there appear to be consistent small band spikes at 2K, 4K and some residual at 8K. This could translate into a degree of harshness and/or sibilance. Also from video analysis the Daizas do seem to significantly reduce those spikes. They may be able to completely remove those if the rubber footers are replaced.
7) Then its just a matter of taking your time to evaluate if you prefer with or without.
8) I have actually learned a thing or 2 from all of this, the remote diagnosing using video is interesting, am going to investigate practical applications.
9) As I understand it, the Bixby voice control agent introduced with the S10 is continuously modifying your microphone input to improve speech recognition. This is something to consider when making video recordings. Just FYI.
Well I have no skin in the game
firstly I was surprised by the difference in the sound quality between the videos
i listened on three difference headphones with different frequency balances
despite Steve assertion it’s all over, its pretty interesting
i have been reading an article on different woods affects on making xylophones
it’s not a dissimilar issue
the first recording has an emaphasis on the formats on the violin, although unnaturally prominent they add a certain vivaciousness to the recording
the Second recording seems to bleach these resonances out and replace with a mid bass emphasis
I would be concerned with a tweak that so fundamentally affected the sound, I was actually really surprised it was so evident
to me the fundamental problem is not the platforms these are on
actually I have no clue what a cms or a daiko even is ?
but I do know about the sound
the first the formats are too prominent on the violin in video 1
in the second video the whole aspect of formats has be quelched
I am not sure that either is corrects, to me the system needs some adjustment without any fancy boards first.....is that the thing we are debating ?
the videos are actually quite good in sound quality and clearly Tang’s system is transparent
I suggest Tang listen to some real violin playing and he will realise the formats are not so overwhelming
the switch to the helmholz wooden resonator is always there but not overwhelmingly
you cannot get there by quelching harmonics
just my two cents ........
