CK, I'm not greedy. One tt, arm, cart...and server will do me.
I know this is not the thread for it, but the Pink Faun 2.16 appeals, both in the base price, and it's upgradeability w multiple OCXOs.
My guess is that it's the competitive outlier to SGM and Wadax Atlantis servers.
Hi Emile and EuroDriver,
My guess is otherwise.
Once you have listened to and examined a real Extreme closely, you may change your mind too.
You will have to see and listen to the real Extreme to appreciate its design and execution.
I have not listened to Pink Faun 2.16x but from its internal photos, I can see that its chassis is filled up by components completely.
On the other hand, the interior of the Extreme is neat and tidy and spacious "to the extreme"!
A day & night difference!
OCXOs, implemented well, can provide a nice sonic uplift for their parts cost, but the following should be noted
- they take quite a while to stabilize and deliver their best sound
- they have their unwanted sound signature too that needs to be managed
What Emile has been able to do in the Extreme setup is to replicate and surpass the OCXO sound enhancing functionality with no downsides that we have been able to detect.
What are the other two cards sandwiching the sfp fiber card?
You put the fiber card in the 4th slot from CPU1. What's the idea behind it?
Would it be in a different slot if it was connected to a NAS/switch or to a DAC?
Thanks
Hi Emile.
I see that on the back of the Extreme, there is only one Ethernet port. He has done tests with a second port that goes directly to the Player without having to go through Switch, like Melco, Innuos and others.
But are any of them ready to transmit directly to the Player without going through the Switch?
Thanks for the reply.Hi Bibo,
Nice catch! Yes we do have preferred card placements for spreading processing loads and card to memory traffic. However it's worth to note that the QPI interconnect between the CPU's, the way we have configured it, has so much excess bandwidth that it's a minor rather then mayor tweak. It's audible though, as almost everything is![]()
Are you going to tell me what are the two cards sandwiching the sfp fiber card?![]()
In Hong Kong, SGM and Wadax are carried by diff dealers.
They are sold not via retailers but directly by the dealers so direct comparison is near-impossible.
However I have a friend who own both!
Because he has to work and stay in Mainland China very often, he has set up another audio system there.
Let me ask him whether he has directly compared Extreme to Wadax Atlantis Server or not.
Will update you if I can get an answer.
So, for top results, one needs a top server, top dac, AND a re-clocker?
Those look like m.2 nvme to pcie expansion cards... for the music storage.
