Hi Emile
Did you try to „play” with different settings ?
Some have very deep effect on the final result. QOS, Latency, priority….
To my ears on the Dream Machine pro router the less functions ON the better SQ.
also the security I had to keep on the lowest level to get best effect.
I turned build in switch off and use the 2 SFPs only + one dedicated WAN.
In my system the lenght of the DAC cable is one of the most important factors.
I should mention not only lenght but the Size of the wires used in that cable.
the longer runs use thicker wires .
It looks this is a very good way to fine tune the overall system balance.
But the 1m sounds so thin in my system I cant listen for longer that 30 min.Longer cable lengths require a larger wire gauge to compensate for the increased signal loss.
Emile, I think you already confirmed this a while ago, but just to be sure for those with limited space: Are the switch, router and DCD stackable without any loss in sound quality? I‘m thinking of a copper / silver / copper finish combo in my case.
Ok, so with just the stock feet and careful placement (and no sliding afterwards) there is still the risk of scratches?
If so, I would cut out tiny pieces of cloth or microfiber to place between the cover part / feet to protect from scratching not adding any unnecessary awkward looking height.
FWIW,I am still trying to get the best socket splitter with or without the filtration.
What are the top options ( very best) I should consider to try in my system?
I have 2 separate 5.3 mm2 lines with Oyaide solid cores.
should I add 3 more direct lines ?
ThxFWIW,
I have only one 16mm2 line terminating into a distribution box in my listening room. From there go hardwired 4mm2 lines to all devices. The connection at the backside of the devices is Neutrik Powercon 32A. With this arrangement I never had the desire to use any power conditioning at all.
Matt
Yeah, this might be even betterI am simmilar , but larger cables are used , 34 mm2 to the main box and 5.3 after that.
There are some noises like a little and low level buzz in speakers and big trafos generate a little humm from time to time so I wanted eliminate that.
Great music. The LSO, w/ Simon Rattle, is also a great recording. Saw this on stage a few years ago— it will always be my reference for the sound of massed strings.Listening thrill of the week, the feeling of being almost on stage, touching the singers is incredible with the latest incarnation of XDMS.
There is a mysterious mix of transparency, see-through layering and physical immanence of the singers which just grabs you by the innermost core emotional means, straight into the story behind the music.
What material is recommended for placing routers and switches on?Wood, glass, acrylic or other MDF materials
Bello! L'ho ascoltato ieri sera e sono rimasto incantato. Grazie mille!Listening thrill of the week, the feeling of being almost on stage, touching the singers is incredible with the latest incarnation of XDMS.
I plan to put the Taiko switch and router side-by-side on top of a very expensive and elegant shelf -- my Taiko Extreme. Hopefully, that is decent enough. . .Something decent, it does respond like any other audiophile device. By now I feel it’s safe to say that the switch and router are part of your system performance and are just as sensitive to the surface they’re placed on as any other device. As the switch and router are “voiced” to be what we consider to be “neutral” that surface can make them deviate from neutral.
Incredibly powerful, Grazie Mille also from me Simone @simorag...Bello! L'ho ascoltato ieri sera e sono rimasto incantato. Grazie mille!
Steve Z
