Anytime![]()
well, i'll be crossing the pond in late july/early august and would love to drop by Taiko's airbnb
Anytime![]()
well, i'll be crossing the pond in late july/early august and would love to drop by Taiko's airbnb![]()
If the Taiko PCIe DAC board can give me the same emotional involvement with my music that the dCS stack currently does -- I'd part with the dCS in a heartbeat!Let me understand....are you saying you will part with your Dcs stack for the PCIe on board DAC? My Horizon ain't going anywhere? Im in long for everything Taiko. I just can't buy into the on board DAC unless as I said before Emile can work his magic and have one with tubes![]()
Thank you very much. Would the Horizon have to go in for hardware update?Here's a summary of posts made in this thread on that subject.
Non modular versionIt would be a main carrier PCB with the controller/interface technology and power circuitry with a connector to which you can connect a daughter board.
The daughter board can then provide a variety of functions like:
-A DAC with analogue outputs
Since the analogue output in this new modular layout no longer need to compete with digital outputs regarding available space, will it still be single ended output, or do you consider doubling up on some components (and accepting generating more heat) by going balanced output? Hope soWe will not release that but split it into a modular design. That actually has a minimal impact as we need to change a few other things anyway
Hi All, here is a schematic representation of the TACDA PCIe card in its initially proposed fixed-output guise,
and in its revised Modular guise.
Please note that we will no longer issue the non-modular version. The TACDA will by definition be Modular, and the analog output version will have the DAC sit on the modular Daughter board.Non modular version
I do not know how big the daughter board is, but hoping for a bit more area than the 25% DAC on the prototype PCIe.
Congrats, really great designHi All, here is a schematic representation of the TACDA PCIe card in its initially proposed fixed-output guise,
and in its revised Modular guise. Note that, for the analog output option, the DAC itself will be contained on the Daughter Board.
I suppose the best sounding DAC on the planet per square inch.......The TACDA will by definition be Modular, and the analog output version will have the DAC sit on the modular Daughter board.
Given the direction in which the platform is heading, wouldn't it be appropriate to revisit the name?The TACDA will by definition be Modular, and the analog output version will have the DAC sit on the modular Daughter board.
I'm not sure if we should change the name of the current thread but it might indeed be a good idea to start a new thread for the TACDA/TACDD, but that's something to consider for later when we're closer to launch and have more info to share.Given the direction in which the platform is heading, wouldn't it be appropriate to revisit the name?
Something simple and generic like :
Taiko Audio CPU Direkt
or
Taiko Audio CPU Direkt Interface/Platform
I share your opinion. It would probably be a good idea to have a thread for each Taiko Audio product.I'm not sure if we should change the name of the current thread but it might indeed be a good idea to start a new thread for the TACDA/TACDD, but that's something to consider for later when we're closer to launch and have more info to share.
So the new PCI modular card will have an output (connector to be revealed) for the new Taiko proprietary interface and also the daughter card connector with different outputs to choose from. Correct?Hi All, here is a schematic representation of the TACDA PCIe card in its initially proposed fixed-output guise,
IIUC, only the daughter boards will have outputs.So the new PCI modular card will have an output (connector to be revealed) for the new Taiko proprietary interface and also the daughter card connector with different outputs to choose from. Correct?
Hi Christiaan,Please note that we will no longer issue the non-modular version. The TACDA will by definition be Modular, and the analog output version will have the DAC sit on the modular Daughter board.
