In the middle of an album the track stops plays. But I think it might have been "version" related. Was prompted to do an update, Just did an update, fingers crossed.
It would help if you mention what software you are running? Roon or XDMS?
Sorry its Roon, and as indicated I think it was different versions related, so far so good!!It would help if you mention what software you are running? Roon or XDMS?
Check to see if the versions on the Extreme/ipad/computer are the same. Go into settings, "about" and you can see the versions that are installed and if upgrades are available...You should see Roon version 2.0 and Build 1223, 1223 Windows, ios you should see 1219...Same problem here with roon stopping suddenly during a track.
That's why I stopped using Roon years agoCheck to see if the versions on the Extreme/ipad/computer are the same. Go into settings, "about" and you can see the versions that are installed and if upgrades are available...You should see Roon version 2.0 and Build 1223, 1223 Windows, ios you should see 1219...
I agree BUT when the alpha version of XDMS is sonically better IMO than Roon, for me it was a no brainer.didn’t most XDMS alpha users have issues with this current upgrade? Software is hard to make perfect.
I certainly understand why..That's why I stopped using Roon years ago
I too have a digital only main system (I have a record player in my second system mainly as a historical conversation piece ), and I agree with what you say, Roon has many positive attributes, and sounds very good on the Extrene.I’ve been using Roon for 8 years now and I think that it is an excellent software solution that allows me to play music all round the house through a variety of different devices from different manufacturers whilst using the same control software and maintaining a common playback history across all devices. The only problem that I have had in that period is once last year when, for some reason, it initiated a fresh installation instead of an upgrade which overwrote my advanced settings and set them back to default. I could hear the difference that this made and it did take me a while to figure out what had happened but, once I changed the settings, the sound quality was back where it was.
Combined with the Extreme‘s streaming sound quality, I find it to be an excellent combination for music exploration and I have discovered more new music in the 12 months since getting my Extreme than in the previous 12 years.
As for sound quality, I cannot comment as I have not heard XDMS yet but, on my system, Extreme Roon sounds superb. That may be because my system has been built entirely around that source, but I cannot highlight any sound deficiencies. Quite often, I let Roon run in Radio exploration mode whilst I am reading or using my laptop and it just stops me in my tracks and makes me look up in surprise. One such occurrence happened recently with this track which was recorded in 1963. It’s just a man, a guitar and a harmonica and not a track that I had ever heard before but my wife looked up and said ‘My God, he’s just right there’ pointing her finger. You could sense his physical presence and, eyes closed, you would swear he was sitting right in our living room. If XDMS is a lot better than that, then I shall be very pleasantly surprised.
What's the track from?This is Roon playing with the new networkcard, DAC cable and switch combination.
@Malcng: Malcom, take a listen to "Vanguard Visionaries/Junior Wells/Help Me (A tribute to Sonny Boy Williamson)I’ve been using Roon for 8 years now and I think that it is an excellent software solution that allows me to play music all round the house through a variety of different devices from different manufacturers whilst using the same control software and maintaining a common playback history across all devices. The only problem that I have had in that period is once last year when, for some reason, it initiated a fresh installation instead of an upgrade which overwrote my advanced settings and set them back to default. I could hear the difference that this made and it did take me a while to figure out what had happened but, once I changed the settings, the sound quality was back where it was.
Restart Extreme…?maybe.I was able to sort the Roon issue out yesterday. Now for some reason I cannot switch to TAS, it only says SGM Controller Is Not Available...Any suggestions?? I restarted the ipad, its nice to be able to correct issues without reaching out to Taiko...
I tried that, it shows that it is connected to the Extreme along with my serial number. SGM controller not available. Also where you switch between Roon/TAS both show stopped.Restart Extreme…?maybe.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
